Subject: Having trouble adding hair to V3 and V4
mercblue22 opened this issue on Jun 22, 2007 ยท 4 posts
mercblue22 posted Fri, 22 June 2007 at 2:05 PM
Hello,
I am trying to add hair to my figure but all I am getting is it either appearing on her head (with a bald spot on top), the hair appearing on the figure but in a stange see through webbing way or the hair does not appear at all. I am positive these are hairstyles for V3 and V4 (it says so) Can anyone help me figure out how to assemble hair on a figure like V3 and V4?
Thanks,
Fonzie
thefixer posted Fri, 22 June 2007 at 2:14 PM
If the hair is a "figure" you conform it in the same way as you would for a clothing item.
If it's prop hair then it usually has a dial to fit various peeps or if it's specific to one it will be a smart prop!
Injustice will be avenged.
Cofiwch Dryweryn.
mercblue22 posted Fri, 22 June 2007 at 2:24 PM
Ahh,
I see, will try again, thanks again Fix! (I got the muscle morph to work too, its incredible!)
Fonzie
pakled posted Sat, 23 June 2007 at 12:37 PM
or if you want to go the hard way;
select the hair, then change the hair selection to 'body', then use x,y,z dials to place it on the head.Once you have it in place (it's harder than it looks), I think you can conform it, but to be honest, I have trouble with that sometimes..;)
