Forum: Vue
Subject: How Do I Set the Default Folder for Added Stuff? V6I
grouch opened this issue on Jun 22, 2007 · 7 posts
grouch posted Fri, 22 June 2007 at 7:34 PM
I'm running V6I under Vista Ultimate 64-bit. I can set the folders for added objects, plants, materials, etc. However, when I go back into the Vue the next time, about half of them are no longer recognized. I get the error that Vue can't find them and do I want to browse to where they are. Once I do that, all is fine... until I open Vue the next time. More info. I had them all on my D: drive and just moved them to another drive - an external drive. Yes, the drive is on, when I'm running Vue. So, I know there's a way to get Vue to recognize material on a drive other than C:. I did it before to get stuff on the D: drive in the first place. Nelia
grouch posted Sat, 23 June 2007 at 3:31 PM
Figured it out!
There was one - count it - one!  file still lurking on my D: drive from the move.  When Vue went hunting for where to put stuff, it evidently stops at the first location it finds content.  Once I deleted this file, Vue correctly then pointed to my H: drive.
A freebie was automatically downloaded from Cornucopia3D and it created a new Vue folder on the D: dirve under my User Documents folder.  I'll have to remember to both move those things and then delete the Vue folder in the future.
Whew!  I sure was getting tired of correcting the path for each item.
Nelia
iloco posted Sat, 23 June 2007 at 3:41 PM
Do you noticed it slow to show collecitions from your external drive after shutting vue off and then going back. :)
ïÏøçö
grouch posted Sat, 23 June 2007 at 8:48 PM
Quote - Do you noticed it slow to show collecitions from your external drive after shutting vue off and then going back. :)
Actually, it wasn't slow.   I was shutting down Vue and going back in a number of times. The only time it slowed down was loading new collections with lots of items.  After that first time, everything loaded quite fast.
Unfortunately, I hadn't solved the default folder thing.  The only thing I can figure at this point is that Vue defaults to User Documents folder on the drive containing the .exe file.
Nelia
grouch posted Mon, 25 June 2007 at 4:06 PM
Got the answer from tech support! :biggrin: Two ways to change the default path: edit teh .reg file, which can be dangerous if you mess it up. Or reinstall Vue. I went the reinstall route and now am much happier with the correct paths. During the installation you're given a choice of where to install the program and where to install your content. No more endless browsing to the external drive, where my content lives. I did suggest they give path options in File, Options. Nelia
chippwalters posted Wed, 27 June 2007 at 12:45 AM
Where did you say the .reg file was located?
grouch posted Wed, 27 June 2007 at 8:50 AM
It's in the Windows directory in Vista.  If you edit it, be sure to save a copy first in case there's a problem.  Also, you need to run Notepad as an admin in order to save the file.
