Subject: Backround movie for rotoscoping?
danb opened this issue on Jun 24, 2007 · 8 posts
danb posted Sun, 24 June 2007 at 6:53 PM
I need to be able to sync my poser character animations to a .mpeg i have.  Is this possible to use a movie as a background image in the front viewport?  If so how do i do that?
Miss Nancy posted Sun, 24 June 2007 at 7:37 PM
Attached Link: http://www.philc.net/
apply the movie to the diffuse channel of the poser 1-sided square. see also phil's rotoscoping item.
danb posted Sun, 24 June 2007 at 9:54 PM
Thank you, very helpful.
danb posted Mon, 25 June 2007 at 10:54 AM
Which movie format should i be using?  I tried .mov with animation and sorenson codecs but got the message "Cannot load not enough memory".  The file is only 4mb.
Any ideas?
Miss Nancy posted Mon, 25 June 2007 at 1:38 PM
how many frames? what frame size? altho I admit, it should be able to load a short clip, so that may be the spurious memory error that poser sometimes gives.
danb posted Mon, 25 June 2007 at 1:59 PM
There are 600 frames at 320 x 240 .  What would be considered a short clip?
Miss Nancy posted Mon, 25 June 2007 at 2:59 PM
I'm getting 176 MB for that. it may be too much; try shorter clips. IMVHO a short clip is 120 frames (preferably 30 - 60), which is about the standard length between cuts nowadays, given the attention span of the current demographic.
adh3d posted Mon, 25 June 2007 at 3:39 PM
YOu can try this program, it is free and can be used to capture from videos to 3d or 3d data. like a mocap.
http://www.geeware.com/introduction.html
I have not tried it, but....
adh3d website
