Forum: Bryce
Subject: Free Bryce 5.5 network rendering broken?
mystic_fm opened this issue on Jun 27, 2007 · 4 posts
mystic_fm posted Wed, 27 June 2007 at 12:18 PM
Has anyone been able to do network rendering with Bryce 5.5?  I used to do this with my purchased Bryce 5.01, but ever since I installed the free 5.5 I haven't been able to get this to work.  Also, the "Use Host to Render" option on the network rendering dialog is missing.
(Note: I had successfully used both full installed Bryce and Bryce Lightning for this before - I've been trying it with full installed copies of 5.5 thus far, with no success ... there's never any connectivity.  And yes, I've turned off firewalls and/or made exceptions for Bryce 5.5, just as I successfully had done with Bryce 5.01.)
Analog-X64 posted Wed, 27 June 2007 at 5:48 PM
Yes "Use Host to Render" option has been removed.
Make sure you use the proper Bryce Lightning with the Version of Bryce in use.
Example Bryce v6.x uses Bryce Lightning v2.0C  which does not work with Bryce v5.0 or v5.5
mystic_fm posted Wed, 27 June 2007 at 6:46 PM
Quote - Yes "Use Host to Render" option has been removed.
Are you saying that you need to install Bryce Lightning on the client computers w/5.5?  In 5.0 a machine with the full Bryce install would work ... Bryce Lightning was only needed if you were going to use a machine as a client without having a full Bryce install on it.
Also, I'm truly stumped as to why "Use Host to Render" was removed.  Usually I'm going to do the bulk of my Bryce scene design on my most powerful computer, so then to have that machine sitting dormant while I do network rendering almost makes it a waste of time to use network rendering at all.
Thinking seriously of going back to Bryce 5.01 at this point ... Daz hasn't impressed me at all with their abilities as a software development house.
nruddock posted Wed, 27 June 2007 at 7:00 PM
ISTR that the trick is to install Lightning as well as Bryce and add localhost (i.e. IP address 127.0.0.1) as one of the rendering nodes.
