skiwillgee opened this issue on Jun 28, 2007 · 16 posts
skiwillgee posted Thu, 28 June 2007 at 10:47 PM
I thought I'd show you a small example to the terrains it can generate and I have only scratched the surface. All the terrains here are single 4096X4096 terrains that take about 2-3minutes to generate and export to Bryce. Once in Bryce you can continue to modify it in Bryce's terrain editor. Each terrain I applied a simple (usually preset mat from B6) and rendered in a context I felt it fit.
This one I free handed the water into the gorge.
skiwillgee posted Thu, 28 June 2007 at 10:49 PM
skiwillgee posted Thu, 28 June 2007 at 10:51 PM
skiwillgee posted Thu, 28 June 2007 at 10:53 PM
BecSchm posted Fri, 29 June 2007 at 6:31 AM
Really nice. They look like they were done in Terragen, which always does great terrains.
donniemc0 posted Fri, 29 June 2007 at 7:34 AM
danamo posted Fri, 29 June 2007 at 12:03 PM
Very impressive terrains. I'm considering getting GeoControl.
Robo2010 posted Fri, 29 June 2007 at 3:41 PM
Hot damm skiwillgee, I like your third image. Me want texture, terrain......
FarawayPictures posted Sat, 30 June 2007 at 1:48 AM
Man! I hope your on comission LOL
I might try this.
Analog-X64 posted Sat, 30 June 2007 at 8:09 AM
I downloaded the Demo but couldnt export anything I tried. Unless I do a screen capture? Bring into photoshop??
alexcoppo posted Sat, 30 June 2007 at 12:32 PM
Quote - I downloaded the Demo but couldnt export anything I tried. Unless I do a screen capture? Bring into photoshop??
I have the registered version and I use the menu command Terrain | Terrain Export... when displaying the Terrain tab (on the right of the program window). I don't remember exactly how things were in the demo, but I think it was exactly the same.
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
pakled posted Sat, 30 June 2007 at 12:53 PM
usually demos have 2 weaknesses;
skiwillgee posted Sat, 30 June 2007 at 6:46 PM
As alexcoppo said, on my full version in tool bar drop dwn menu it is terrain/terrain export/PGM for Bryce. The export function may be disabled in demo. Save function may be disabled in demo also.
Since bryce accepts pgm terrains you can click the "e" and edit it once it is inside bryce (example- add noise or gaussian edges)
ysvry posted Sat, 30 June 2007 at 10:37 PM
Did you know I asked for that feature while alpha testing gc, good to see people like it, also respect must go to bikermouse and as,as they showed me that bryce could import pgm to get higher resolution in terains.
BecSchm posted Sun, 01 July 2007 at 10:33 AM
Analog-X - I downloaded the demo, and it IS fully functional.
alexcoppo's directions for saving the terrain in GeoControl work the same way in the demo version.
In Bryce, to import your terrain, go to File - IMPORT OBJECT - then upload your pgm file. It will load up as an editable terrain.
I'm gonna play around with it and hoping to get some great looking terrains! There aren't any presets with the demo.
BecSchm posted Sun, 01 July 2007 at 6:17 PM
Correction; the presets are working, too.
