Subject: P7 freezes after turning a few times the parameterdials
tigerkidden3d opened this issue on Jul 01, 2007 · 6 posts
tigerkidden3d posted Sun, 01 July 2007 at 10:41 AM
Hi,
I'm using Poser7 under Windows XP.
When I edit figures, props or bodyparts with the parameter-dials like "xrotate" "ytran" ..... more then lets say 5-10 times, Poser7 freezes.
The only thing working is "SAVE". When I close Poser7 at that moment and reopen the file again, everything is fine until the next "freeze" when "turning the dials".
With the same file, on the same PC but with Poser6 it NEVER happens.
Does anyone know what causes this problem?
Thanks.
ockham posted Sun, 01 July 2007 at 12:42 PM
Guessing: Could be the Undo mechanism.  Try going into Prefs (Ctrl-K)
and setting the Undo number down from its default 100 to something
more reasonable like 10.
My python page
My ShareCG freebies
Tormentor posted Sun, 01 July 2007 at 6:08 PM
You're lucky ! My Poser 7 simply disappears without reason, if not that it waits the moment when I made a long work and saved nothing...
Posette, and no else ! Posetteforever
tigerkidden3d posted Wed, 04 July 2007 at 3:15 AM
Hi ockham,
I did as you said  put it from a 100 to 10 and even to 1. Now it seems a lot better but not satiesfying at all.
But thanks for your idea and help anway :-)))))
ockham posted Wed, 04 July 2007 at 12:02 PM
Is your Poser installed on an external hard disk, or a networked
disk, or something like that?  Poser doesn't enjoy such
arrangements ... it's usually better to keep it entirely "inside the box."
My python page
My ShareCG freebies
tigerkidden3d posted Fri, 06 July 2007 at 1:16 PM
Yes, Poser 7 is installed on "C" and the runtime-folders are on an external harddrive "W"  for savety reasons.
But with Poser 6 its the same: Poser 6 installed on "C" and the same runtime-folders are on "W" the external harddrive.
