Forum: Carrara
Subject: Fog Effect Is Messing Up Alphas
Davaris opened this issue on Jul 01, 2007 · 8 posts
Davaris posted Sun, 01 July 2007 at 11:26 PM
Hi Everyone,   I made some low poly girders to build a big structure. I used an alpha map to cut the holes in a three sided polygon and it worked fine until I tried to use the fog effect on the scene. As you can see from the picture, it looks like the fog has doubled inside those girders at the back. Can anyone tell me how to fix this?
EDIT:
The higher up girders aren't inside the fog effect.
