Forum: DAZ|Studio
Subject: INJectors... How to use?
Naaman opened this issue on Jul 03, 2007 · 12 posts
Naaman posted Tue, 03 July 2007 at 12:46 PM
So, I've looked through the readme file for this product and I've looked at the Daz instruction manual, but I can't find any info on how to acutally use the muscle morph injectors that I bought yestersay.
When I open the folder (within the Daz program) and assigne the injectors to a figure, no visible change occurs, and no additional options appear on the paramiters menu (no dials or anything).
How do I acutally get them to work, or to have an effect on the character?
Here's a link to the product.  Maybe there's something in there that will explain that I don't have the knowledge to interpret.
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=3940&cat=13
Help appreciated.
Incognitas posted Tue, 03 July 2007 at 1:34 PM
You do HAVE the Victoria 4.1 Morphs I hope?They are the product besides Vicky 4.1 that you need.
RHaseltine posted Tue, 03 July 2007 at 1:59 PM
Actually, you need Morphs++ only for the full body morphs (Amazon and so on) which are pseudo morphs made up of sub-morphs from the Muscle and ++ sets.
The Muscle Morphs appear as a separate group, under the other morph groups for Victoria 4.1 (not Victoria 4 plain). If they aren't appearing make sure that you aren't using the Rem poses, that you installed to the same folder as for the base figure (and Morphs++ if you have it) and that you ran the updater utility (or for Windows allowed the installer to run it),
Naaman posted Tue, 03 July 2007 at 1:59 PM
Yes, I have Morphs++ for V4.1
Naaman posted Tue, 03 July 2007 at 2:05 PM
Hmmm... I'm not sure I understand.  Other morph gourps?  Other than what?  And Rem poses...? I have some "muscle" poses that came with it, but they are just poses.  They don't change the musculature ofthe figure.  In the INJectors folder, there is a "+" injectors and a "-" injectors icon that apparently adds or removes the injectors from the figure, but again, selecting either of these has no effect that I can find.
GKDantas posted Tue, 03 July 2007 at 3:15 PM
If you have Vic 4.1 you need to run a script ta add these new morphs to the Vic 4.1 installation... when you install Vic 4.1 its ask to create a shortcut at your desktop called "Update Victoria 4.1"
All time that you buy a new morph group for Vic 4.1 its suposed that it runs this script at the end of the installation...
Follow me at euQfiz Digital
Naaman posted Tue, 03 July 2007 at 3:54 PM
Right, and then a window opens up in DOS and you see it run the script and then, presto!  Everything should work.  I ran the script.  But I can't figure out how to make the Injectors do anything (or, rather, I don't see any way to manipulate them in Daz, where should I look for the dials etc?).
GKDantas posted Tue, 03 July 2007 at 9:04 PM
I dont have this morphs yet... some morphs has right place to be founded, but these I really dont now where...
RHaseltine posted Wed, 04 July 2007 at 8:41 AM
When you look at the body of V4 you should see closed morph groups in the Parameter palette - this is what you should see with just V4.1 loaded
and this is waht you should see after injecting the morphs
Naaman posted Wed, 04 July 2007 at 1:59 PM
Trying it now... I don't remember seeing any Muscle Morphs options... but I'm going to load up the program and see what I get.
Thank you, this is EXACTLY what I was trying to find out.
Loading Daz*
And I'm back.... Nope.  No Muscle Morphs.  There is an icon on the left that shows a very beefy victoria with a + sign in the corner of the icon, there is also an icon next to that one that has the same picutre in black and white with a "-" in the corner.
Is there a step that I'm missing?  I load a figure, I go to Content > Poses > DAZ's Victoria 4 > Morph Injections.  Then I click on the icon.  I get a little loading window in the center of the screen, and then it disappears without changing anything....
I'm going to try re-installing.
Naaman posted Wed, 04 July 2007 at 2:08 PM
Woohoo!!! Fixed it!!!  I re-ran the 4.1 update, and then reloaded the program and injected the muscle morphs.  It works now.
Thanks for the help everyone.
