Forum: Poser Technical
Subject: Some short video about how to use CR2Builder.
kim99 opened this issue on Jul 10, 2007 · 13 posts
kim99 posted Tue, 10 July 2007 at 4:48 AM
I make some short video about how to use CR2Builder.
http://briefcase.yahoo.co.jp/bc/kim99x2003/lst?.dir=/f29e&.order=&.view=l&.src=bc&.done=http%3a//briefcase.yahoo.co.jp/
*02m12g-HowAboutERCAnalize
*02m12gRepare.wmv
*CR2Builder-DragAndDrop.wmv
*CR2Builder02m12gFlagAutoEncoding.wmv
*MakeEzINJ/02m12h-RenameEzINJe.zip
*MakeEzINJ/02m12h-MakeEzINJ.wmv
CR2Builder02m series
http://briefcase.yahoo.co.jp/bc/kim99x2003/lst?.dir=/21c6&.order=&.view=l&.src=bc&.done=http%3a//briefcase.yahoo.co.jp/
Cage posted Thu, 12 July 2007 at 11:49 PM
This is great!  Thank you!
I'm glad to see version 02m12h.  I encountered a couple of bugs in 02m12g and went back to using 02k18.  The m series seems to be much faster!!!   :woot:
kim99 posted Tue, 17 July 2007 at 8:36 PM
Cage.
Thank you.
02m12g have  a bug that could not save right page because It could not show saveDialog.
If you know other bugs, Please teach me that.
Everyone
Please teach me a impression about some videos.
 Do you understand "ERC Analisis"  and "EzINJ" ?
02m12g  could save file that's encoding is UTF-8N when it is included the key ward "version  7".
Cage posted Tue, 17 July 2007 at 10:30 PM
With 02m12g I think I tried to drag and drop something to the right page and encountered an error popup.  After that, all menus were grayed out and the program wouldn't even respond to close.  Luckily I didn't lose any work.  I also encountered a problem with the new multiple tabs for the right page, when I tried to close too many of them.  The main trouble I had was the no save bug for the right page.
I love CR2 Builder.  One of my most-used applications!  :woot:
kim99 posted Wed, 18 July 2007 at 2:21 AM
02m series make new page, when drop file on the main form(window). I guess that a factor of this bugs is the contents of file droped. If you encounter same error with 02m12h, Please send me the file. I will try to happen same error with 02m12h.
for your reference.
If you close right pages all,
Shall you select the menu item  [RightPage]-[Exstra]-[Close All].
Cage posted Sun, 22 July 2007 at 12:14 AM
kim99 - I've had the same error I mentioned before, due to dragging and dropping from left to right, in the new 02m12h.  Here is a screen capture of the error, showing what I was trying to drop.
This error occurs with both the RightTV and the ExtraTV.  The error does not occur if a complete actor is dragged and dropped, but it does happen when parameter dials alone are dragged.
kim99 posted Sun, 22 July 2007 at 10:06 PM
Cage, Thank you.   I have watched same dialog too. I report it if recovered.
When you watch the bug like that, Push "Done" Button. ( Top Right on the Main Form.)
You will be able to other operation (ex. save file.) with the CR2Builder.
because  CR2Builder takes down a flag doing  ( processiong ).
Cage posted Sun, 22 July 2007 at 10:58 PM
Aha!  Good to know that there's a way to help the program recover from the error.  Thank you!  :)
kim99 posted Tue, 24 July 2007 at 5:20 AM
CR2Builder02m12k.zip  Release.
http://briefcase.yahoo.co.jp/bc/kim99x2003/lst?.dir=/21c6&.order=&.view=l&.src=bc&.done=http%3a//briefcase.yahoo.co.jp/bc/kim99x2003/lst%3f%26.dir=/21c6%26.src=bc%26.view=l
This bug was fixed.  Will you try it ?
Cage posted Tue, 24 July 2007 at 11:06 PM
I used 02m12k for several character and pose edits today and encouontered no errors.  Looking good!  :woot:
kim99 posted Wed, 25 July 2007 at 10:29 PM
Thank you. Cage.
When you encounter other errors, please notify me too.
Cage posted Sun, 12 August 2007 at 3:44 PM
I've encountered another error similar to the last one.  In this case, I dragged a block of ERC from the left page to the right and encountered the error when I tried to drag a copy back to a new parameter on the left.  The error occurs when I try using the extra page as well as the right page.  This error is less consistent than the last one.  Sometimes I get a popup dialog asking me to verify some information about the dropped parameters (I've forgotten what it asks 😊) before the error comes up.  Clicking on "done" has not restored the program after this error.  I've found it in all the 02m builds I've tested, but not in the earlier k version I was using before.
kim99 posted Sun, 12 August 2007 at 10:42 PM
Thank you. Cage >Sometimes I get a popup dialog asking me to verify some information about the dropped parameters >(I've forgotten what it asks ) before the error comes up.  New function of  the CR2Builder02m. Let you see the figure.  >Clicking on "done" has not restored the program after this error. I guess that you selected "CANNCEL" button. Sorry. 02m12m have a bug that you reported. This bug was fixed. CR2Builder02m12m.zip  Release. [ http://briefcase.yahoo.co.jp/bc/kim99x2003/lst?.dir=/21c6&.order=&.view=l&.src=bc&.done=http%3a//briefcase.yahoo.co.jp/bc/kim99x2003/lst%3f%26.dir=/21c6%26.src=bc%26.view=l](http://briefcase.yahoo.co.jp/bc/kim99x2003/lst?.dir=/21c6&.order=&.view=l&.src=bc&.done=http%3A//briefcase.yahoo.co.jp/bc/kim99x2003/lst%3F%26.dir=/21c6%26.src=bc%26.view=l)
