alpha117 opened this issue on Jul 10, 2007 · 7 posts
alpha117 posted Tue, 10 July 2007 at 2:28 PM
We all know how tedious it is to conform each item to the main figure, especially if the clothing has many items. I was wondering if there is a way to conforming all items in one go, perhaps a script or somethink.
Many Thanks
kalon posted Tue, 10 July 2007 at 2:32 PM
There are a few scripts, this is just one (script is in the first message- looks like a txt file, you'll have to download and change the extension)
www.renderosity.com/mod/forumpro/showthread.php
Try searching the Poser Python Scripting forum for "conform" and search beyond 45 days out.
alpha117 posted Tue, 10 July 2007 at 2:49 PM
thanks
Extension to .py?
alpha117 posted Tue, 10 July 2007 at 3:03 PM
Ok, just changed it to .py and it works a treat, what a time saver. Many Thanks.
Just need to know if it is possible to run two scripts together.
Cage posted Tue, 10 July 2007 at 3:18 PM
Run multiple scripts with one click? Python scripts can call one another, so you can create a sort of runner script.
import poser
poser.ExecFile("Runtime:folder:script1.py")
poser.ExecFile("Runtime:folder:script2.py")
poser.ExecFile("Runtime:folder:anotherscript.py")
The above lines between the # signs should work as a script if saved as a .py file. Change the paths as needed, using Poser's Mac-style relative Runtime paths. As far as I can tell from my own experiments, the colon before "Runtime" should be omitted for these, although I'm not sure why....
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
infinity10 posted Tue, 10 July 2007 at 10:53 PM
cage - the scripts have to be cleared from memory before next one can execute ie sequential execution, ?
(I am not python programmer,but do know that I can't get more than 1 python script working inside of my Poser 7. So a sequential execution is what you're saying, right ?)
Eternal Hobbyist
Cage posted Tue, 10 July 2007 at 11:12 PM
I suppose you could say sequential execution, yes. The short script sample I posted would automate the sequential running of multiple scripts. It sort of reads to me like perhaps you have a different problem than I thought, however. What exactly do you want, when you ask about two scripts running together? One script can run another script, as I showed. You're trying to manaully run two or more scripts at the same time, perhaps?
