Subject: High Res Body Texture
Robert_Ripley opened this issue on Jul 11, 2007 ยท 6 posts
Robert_Ripley posted Wed, 11 July 2007 at 12:31 PM
I got problem with body textures, as you see on the pic how detailed the texture file is and the render i did with it....it would be cool if it would look like the that.
If you can help me please discribe exactly how do i do the setup with poser 5...cause i dont get it ;)
Thx anyway
cedarwolf posted Wed, 11 July 2007 at 12:48 PM
Bookmarked because while I have no idea what the answer is, I want to know also.
Miss Nancy posted Wed, 11 July 2007 at 1:06 PM
turn off texture filtering (if they had that in P5), increase pixel samples, decrease shading rate to 0.01, post filter=1, et al.
Robert_Ripley posted Wed, 11 July 2007 at 5:06 PM
nancy can you add some screenshots of it?
i even rendered on the highest render setup...turned of tex. filtering...but nothing worked yet
ashley9803 posted Wed, 11 July 2007 at 7:28 PM
Doesn't look too bad to me.
How large is the texture map?
Miss Nancy posted Wed, 11 July 2007 at 7:40 PM
bob, I don't use P5 any more (lousy piece of bugware IMVHO), but if texture filtering is off, then see if there's a maximum texture size setting in the render settings.
