Subject: Rendering eyelashes and hair with Firefly
Mogwa opened this issue on Jul 12, 2007 · 10 posts
Mogwa posted Thu, 12 July 2007 at 12:01 AM
I sometimes encounter a frizzy or clumpy look when rendering eyelashes and dynamic hair using Firefly with raytracing on. Does anyone have suggestions on what settings are best suited to avoid this problem?
(After spending more time working with Victoria 4, I'm starting to revise my less than entusiastic original opinions of her capabilities. Once I get the rendering setting worked out, I think she'll be capable of producing some really stunning art.)
pjz99 posted Thu, 12 July 2007 at 12:40 AM
You may want to disable texture filtering for the eyelashes transmap (I did); for dynamic hair, can you show an example of what you're talking about?
My Freebies
kalon posted Thu, 12 July 2007 at 9:17 AM
I'm not at my computer and have a very wretched memory, but I think also if you lower the shade rate it will help defuzz hair and eyelashes.
kalonart.com
vincebagna posted Thu, 12 July 2007 at 9:26 AM
Sometimes texture filtering can make your eyelashes worse. Try to turn it off.
Mogwa posted Thu, 12 July 2007 at 2:48 PM
Hers's an example; notice how clumpy the eyelases appear. My render settings in Firefly with raytracing on and texture filtering off: Raytrace bounces 4 Main shading rate 4 Pixel samples 4 Bucket 64 Post filter size 1
nruddock posted Thu, 12 July 2007 at 3:17 PM
Quote - Main shading rate 4
The shading rate is far too large to be good for very fine features like eyelashes.
Try something much smaller say 0.01 (you'll need to set this value both in the Render Settings and on the appropriate object).
stewer posted Thu, 12 July 2007 at 3:47 PM
0.01 is too low for most cases - it'll just slow down rendering. In my experience 0.2 with filtering on should cover most cases.
bagginsbill posted Fri, 13 July 2007 at 8:25 AM
My opinion? Get a new transmap. The eyelashes that come with V4 suck compared to the V3 eyelashes.
I don't know what happened but somebody made a booboo. They are terrible. I'm very experienced with render settings, have no problems with V3 lashes, but V4 always look bad.
Mogwa posted Fri, 13 July 2007 at 3:07 PM
Quote - My opinion? Get a new transmap. The eyelashes that come with V4 suck compared to the V3 eyelashes.
Exactly!!  After hours of frustrating tweaking with the settings, nothing seems to help V4's lashes, but V3 renders are never a problem. I've encountered a few similar "clotting" effects of fine detail with some commercial hair products, and I suspect it's due to the same cause.
Can anyone recommend a good replacement transmap before I'm forced to make my own (he puled in a disgusting whine) ?
And, as always, thanks to all for the help and suggestions!
Miss Nancy posted Fri, 13 July 2007 at 3:13 PM
I dunno if the v4 lashes are mapped the same way as the v3 lashes. but in any case, it might be possible to adapt a v3 map to the v4 lashes.
