chohole opened this issue on Jul 19, 2007 · 8 posts
chohole posted Thu, 19 July 2007 at 2:36 PM
The P6 render on the left of enclosed image was rendred in P6, (using p4 renderer) while the other was rendered in pure P4.
Why am I getting the inside of the dress showing up as black rahter than the fabric colour?
I have used exactly the same settings and lights, in fact I just opened the P4 file in P6.......but I get this problem all the time.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
RAMWorks posted Thu, 19 July 2007 at 2:42 PM
Wish I could help you hon but it's a lovely dress texture in any case!!
Nice to see you here as well!!
Richard ;-)~
---Wolff On The Prowl---
nruddock posted Thu, 19 July 2007 at 2:48 PM
Ticking the "Normals_Forward" box for each relevant material zone will probably make the P6 renderer give the same result as the P4 one.
Having said that, the P6 render as currently shown, is probably correct unless you've got a light positioned to illuminate the dress from underneath.
chohole posted Thu, 19 July 2007 at 3:06 PM
Ok thanks...I guess them normals thingies are under the advanced tab?. I am using P6 on someone elses PC, just trying it out to see if I can work with it, and haven't got as far as the advanced mat lab.
Hi Richard, while you are over here, go check my gallery out, see what I can do when I am not using all my time making textures :lol: Rend has always been my spiritual home, and as you will see Bryce is my normal prog of choice.
SYNTRIFID posted Thu, 19 July 2007 at 4:22 PM
Normals Forward is found in the Material Room in the main Poser Surface box.. (yes the advanced tab)
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
infinity10 posted Thu, 19 July 2007 at 10:24 PM
I don't think the Poser 6 P4 render engine and the Poser 4 render engine are the same, actually - tought I read somewhere that they are not the same.
Eternal Hobbyist
nruddock posted Fri, 20 July 2007 at 2:37 AM
Quote - I don't think the Poser 6 P4 render engine and the Poser 4 render engine are the same, actually - tought I read somewhere that they are not the same.
I think the difference is that some aspects of the shader trees get taken into account, unless you turn on "Ignore Shader Trees" (I think that's what the setting is called).
chohole posted Sat, 21 July 2007 at 9:48 AM
Normals forward and now I can see the back of the dress.
