Forum: Carrara
Subject: Need Help To Get A Particular Kind Of Look
Davaris opened this issue on Jul 24, 2007 · 4 posts
Davaris posted Tue, 24 July 2007 at 5:51 PM
Hi Everyone,    I'm trying to get a special kind look for some pre-rendered game maps I'm making in Carrara 5 Pro.
As you can see the scenery in this example image is pre-rendered, but it also has the painted look I am after.
So far the only good renders I can get are photorealistic, so I was wondering if any one could give me a few ideas as to what settings or plugins I should use to get this kind of render.
MarkBremmer posted Tue, 24 July 2007 at 6:03 PM
This does involve many texture maps and that's what predominantly creates that "look". The lighting looks simple enough: one main light with shadows turned on and a fill light from about the 90 degree left position with shadows turned off and intensity set to something lik 30 percent. You'll just have to experiement a bit! :) Mark
Davaris posted Tue, 24 July 2007 at 6:09 PM
Thanks Mark I'll give it a shot. :)
AndyCLon posted Fri, 27 July 2007 at 4:36 PM
You could try using a prerendered backdrop and some shadow catchers.
The toon settings also might help but don't over do it.
