Subject: Clouds and Lense flares?
starmage opened this issue on Jul 26, 2007 · 3 posts
starmage posted Thu, 26 July 2007 at 11:29 PM
Hi All
Are clouds and Lense flares possible in Poser 7?
If so does anyone know of a tutorial that could take me through the steps of it?
Thanks
Only your mind limits yourImagination. Let it free.
SamTherapy posted Fri, 27 July 2007 at 5:46 AM
Clouds are easy in P6 and I guess it works the same way in P7.
In the material room you'll find a Node called 3D Textures.  CLouds are in there.  Just stick the node into the Diffuse_Color channel for a real simple cloud effect.  There are several parameters you can play around with in the node or, you can build up a more complex shader to get different effects, such as sunrise/sunset, storm clouds, overcast and so forth.
Lens flare is theoretically possible but I've never seen it done.  You could fake one with a transparent square and a shader or texture plugged into it.  For all I know, P7 supports real lens flare but I have never heard it mentioned.
cyberscape posted Sat, 28 July 2007 at 12:34 PM
Here's a good example of how to do it with Coleus' fog prop : http://poser.webz.cz/ (go to bottom of page for download)
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
