Forum: Vue
Subject: Light through curtains
fyrecomix opened this issue on Jul 27, 2007 · 3 posts
fyrecomix posted Fri, 27 July 2007 at 1:40 AM
Hi all,
I was wondering if anybody had an idea how to make realistic light through curtains in Vue.  I have played around with volumetric light and some of the material settings, but have yet to find anything that works.
I am looking for the soft kind of glow you see when the sun shines through white curtains.
Any ideas?
Thanks,
Joe
wabe posted Fri, 27 July 2007 at 1:55 AM
You should read about the use of light gels in the manual. I think this is exactly what you need. Add a gel to a spotlight and then modify this gel to your needs.
AVANZ posted Fri, 27 July 2007 at 2:02 AM
Give it a little bit of transparency, try 5 to 10% or so. To ad on more realism give the material a bump, so you start to see a patern when light comes through. You could also try to drive a variable tranparency with the bump map. There is a noise node in the function editor called "fabric" which works quite well. Cheers!!
