Forum: DAZ|Studio
Subject: Re: Daz3d to Poser export
DOM1 opened this issue on Aug 03, 2007 ยท 2 posts
DOM1 posted Fri, 03 August 2007 at 7:38 PM
I'm trying to export an object from Daz 3d 1.7 to Poser 6. Most of the time it works, however when it comes to objects such as the millennium horse, the fine hair material never exports properly to Poser. I get the black block instead of the fine hair material. I have installed the Poser material scripts. Can someone tell me the correct settings when exporting to Poser.
Any help would be greatly appreciated.
Regards
GKDantas posted Fri, 03 August 2007 at 8:08 PM
Not really a settings problem. When you export some objects with transparency textures you need to remap some channels in the other software. The same happen when exporting to Carrara.
You need to load the transparency map (a black and white image) into the right channel: in Carrara it need to be loaded into the Alpha channel, I dont know what is the right channel in Poser 6.
Follow me at euQfiz Digital
