max- opened this issue on Aug 07, 2007 · 10 posts
max- posted Tue, 07 August 2007 at 2:42 PM
Attached Link: machine 1
As a follow up to my last post, I came back to the 'machine' project which I gave up on in frustration yesterday. I managed to clear the messed up key frames and ran the new animation. There are still some limitations that I can't get around yet, like constraining the loose rod ends to one dimesional movement. Here's the link( I hope it works OK):http://s161.photobucket.com/albums/t227/nimos2/?action=view¤t=machine1b.flv
"An Example is worth Ten Thousand Words"
vkirchner posted Tue, 07 August 2007 at 3:20 PM
Wow, nice job. I never thought much about setting something like that up. Hmmmm!
gregsin posted Tue, 07 August 2007 at 3:26 PM
Great job setting up that animation. I tried it once and never got it all to rotate as I wanted.
max- posted Tue, 07 August 2007 at 3:47 PM
By the way, just rotating the first wheel rotates everything else. It's all a chain of links from wheel to rod, to another wheel.... it's rather basic, but at least it works. I figured it out mostly by trial and error, and a bit of common sense.
alexclark posted Tue, 07 August 2007 at 7:05 PM
There must be some incredible linking behind that. Well done!
Rayraz posted Tue, 07 August 2007 at 8:09 PM
wow how'd u do that??
(_/)
TheBryster posted Wed, 08 August 2007 at 4:23 AM Forum Moderator
I WANT YOUR BABIES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Seriously - Could you post the BR file ? I've been trying to do that on my locomotive model.
Please - pretty please!
max- posted Wed, 08 August 2007 at 10:23 AM
Can a Bryce file even be posted here? How?
But like I said, I haven't solved the problem of constraining the loose end of the rod, like you would see in a locomotive, for example.
max- posted Wed, 08 August 2007 at 1:15 PM
Attached Link: bryce machine 1
Never mind the last post.... I just figured out a way to post the original file of the machine. The link should get you there."An Example is worth Ten Thousand Words"
TheBryster posted Thu, 09 August 2007 at 6:48 AM Forum Moderator
Sorry! I should have sent you an e-mail!
Many thanks anyway!
'Looks forward to playtime'
