keppel opened this issue on Aug 18, 2007 ยท 3 posts
keppel posted Sat, 18 August 2007 at 1:05 AM
Attached Link: The ATLAS MMR-1
This sci fi weapon is a futuristic heavy artillery/railgun styled military land based attack unit. With the correct manipulation of the gun dials it is capable of firing from each gun barrel independently, together in sync, or with an alternating rate of fire. The central column can be raised and lowered which then permits the guns to be rotated on the horizontal axis a full 360 degrees. The guns can also be rotated on a central axis allowing the elevation of the guns to be changed. This allows the ATLAS MMR-1 to be capable of firing at virtually any attack, from any direction, which comes at it from land or air. The feet of the ATALS MMR-1 can be raised or lowered allowing the ATLAS MMR-1 to adjust and stabilize its firing position on uneven terrain. Any suitable character that you put in the gunners seat can be properly posed so that all controls and sighting mechanisms are in the correct relative positions. The gunner can also be secured in place with a harness that raises and lowers. The guns firing control column can also be moved forwards and backwards to allow the gunner easy access to the gunners cushioned seat. This model is highly detailed and extremely versatile.My Renderosity Store
Virtual Furnishing
My Portfolio
keppel posted Sat, 18 August 2007 at 1:08 AM
bnetta posted Wed, 22 August 2007 at 1:56 PM
Free templates available at meshmanglers site.
(see readme info)
Free Textures Pk being uploaded and available soon!!
netta
