V-E-N-0-M opened this issue on Aug 21, 2007 · 11 posts
V-E-N-0-M posted Tue, 21 August 2007 at 8:50 PM
Thanks
Lighthorse posted Tue, 21 August 2007 at 9:01 PM
Which program Daz Studio or Poser Both different.
Daz select Create and pick the type of light you want,
do one at a time select the light and play with its settings
you will see the effect it has, then delete it and try a different
one and so on untill you see what each will do. Do a test render
to see how things turn out.
Poser I do not use.
Lighthorse
FalconArts.Com
JenX posted Tue, 21 August 2007 at 9:03 PM
Ok, first things first, have you figured out how to Add a light? Also, what version of D|S are you using?
Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
V-E-N-0-M posted Tue, 21 August 2007 at 9:03 PM
i use DAZ Studio, now what about clothing textures? I never tried it and done know what program to use for it
Lighthorse posted Tue, 21 August 2007 at 9:08 PM
Paint Shop Pro
Adobe Photoshop
Just to name two.
Download the templet file Check it out.
That should help start you. Check back yhen you see the templets
Its not that hard
Lighthorse
FalconArts.Com
V-E-N-0-M posted Tue, 21 August 2007 at 9:21 PM
i have a black backdrop, how do i make it go back to white?
V-E-N-0-M posted Tue, 21 August 2007 at 9:29 PM
Quote - i have a black backdrop, how do i make it go back to white?
Nermind that, i got it
Lighthorse posted Tue, 21 August 2007 at 9:31 PM
Interface Layout
I find that Black is better to work with.
Got to go be back tomorrow
I guess I should have asked which version I assumed the latest
Lighthorse
FalconArts.Com
grylin posted Sun, 26 August 2007 at 10:02 AM
Attached Link: http://www.runtimedna.com/mod/filelib/index.php?section_id=31
hey runtimedna has a whole bunch of lights bthw:) i ave all of them and they afre very good i think, for all sorts of renders:D good luck:)maclean posted Sun, 26 August 2007 at 10:32 AM
V-E-N-0-M posted Sun, 26 August 2007 at 11:02 AM
Thanks that'll help me out alot,
