FrankT opened this issue on Aug 25, 2007 · 3 posts
FrankT posted Sat, 25 August 2007 at 12:01 PM
Does anyone know if the materials from a mixed material will cast shadows on each other ?
Imagine a brick wall with a plaster coating which has come off in patches. Will the plaster cast shadows on the bricks ?
Regards
Frank
nruddock posted Sat, 25 August 2007 at 3:01 PM
Quote - Does anyone know if the materials from a mixed material will cast shadows on each other ?
If you use bumps, then you won't get a shadow, but it still should look correct.
If you use displacement, then you should get a real shadow.
FrankT posted Sat, 25 August 2007 at 6:54 PM
rats - I was hoping not to have to use displacements, they play havoc with this computer for some reason. I'll give it a go though - thanks for the info
