Subject: Animation with transparent background
oliveramberg opened this issue on Aug 27, 2007 · 6 posts
oliveramberg posted Mon, 27 August 2007 at 7:51 AM
Hi!
I should make some animations with transparent background. Is this possible in Poser 7?
Thanks for your advices.
Cheers - Oliver
jonthecelt posted Mon, 27 August 2007 at 8:48 AM
If you make your animations as a series of .tif image files, to be compiled later in your video editor of choice, then they will take an alpha channel across with them.
Hope this helps,
JonTheCelt
SYNTRIFID posted Mon, 27 August 2007 at 8:56 AM
Yeah, you'd need to render your frames to a format that supports alpha (.tif, .tga, .png) and use the alpha channel to mask out the bg.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
oliveramberg posted Mon, 27 August 2007 at 8:57 AM
Thank you guys!!!
raven posted Mon, 27 August 2007 at 9:10 AM
HuffyUV is a codec that will give you an alpha channel in an animation.
This link is info all about HuffyUV.  http://neuron2.net/www.math.berkeley.edu/benrg/huffyuv.html
This link is to get the codec.  http://www.divx-digest.com/software/huffyuv.html
This thread has Little_Dragon explaining how to configure it when rendering an anim from Poser.  http://www.renderosity.com/mod/forumpro/showthread.php?message_id=714659&ebot_calc_page#message_714659
So you can do it with an animation, but as the guys above say, it's probably better to render to individual frames.
oliveramberg posted Mon, 27 August 2007 at 9:44 AM
Thanks raven!
