I am using the "Distant to Shore" function to create a shoreline, but I don't know if I am positioning or sizing the plane correctly in my scene. As you can see the shore is working, but the rest is not. I am not sure if I should be making the plane (the one with the shore) huge like 800m x 800m or if it should be small and blend with the "Infinite Ground Plane"? Also the shore is the same "Shasta" material as the "Ground" so why do they look so different? Any help would be appreciated. Thanks!
