Subject: Poser Smoke Plumes
bagginsbill opened this issue on Aug 28, 2007 · 13 posts
bagginsbill posted Tue, 28 August 2007 at 4:22 PM
Attached Link: Smoke Plumes at RDNA
Need realistic smoke plumes in Poser?
Head on over to the Node Cult at RDNA. After a lot of work, I made a tricky morphable prop and a few shaders to get you started.
Chuga chuga chuga chuga, chooo chooo!
SYNTRIFID posted Tue, 28 August 2007 at 4:44 PM
This looks like something that could be quite useful!  Thanks.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
SamTherapy posted Tue, 28 August 2007 at 5:04 PM
Looks superb, BB.  I'l take a look at it tomorrow when I'm actually awake and functioning.  My brain is currently heading for the BSOD.
infinity10 posted Tue, 28 August 2007 at 8:44 PM
O Grand Master of the Node BB,
I hail your genious and generosity.
Eternal Hobbyist
cherokee69 posted Wed, 29 August 2007 at 7:03 AM
Awesome prop BB. It looks great. You weren't kidding when you said it renders slow. So, I tired it out one the scene I'm working on. The scene has 2 riverboats, a background image on a one sided square and your water shader. With one of these smoke plumes, Poser 6 and Poser 7 just about hangs. the riverboats have 2 smokestacks each so I'll have to use 4 of the plumes and by the way it's rendering with one, 4 will probably kill Poser.
Latexluv posted Wed, 29 August 2007 at 1:56 PM
Simply fantastic! Just installed the prop and material shaders.
Weapons of choice:
BastBlack posted Sat, 01 September 2007 at 2:04 PM
Wow, that is great! ^^
UVDan posted Sun, 07 October 2007 at 5:44 PM Forum Moderator
Thanks alot.
Free men do not ask permission to bear arms!!
bagginsbill posted Sun, 07 October 2007 at 6:39 PM
Hey folks - cherokee and I worked out that sometimes it's better to render the smoke by itself and save that as a PNG. Then attach the rendered smoke to a prop so it doesn't have to do the math any more, or just overlay that in photoshop.
Just a tip. Saves time.
Tucan-Tiki posted Sun, 07 October 2007 at 11:09 PM
Or you can make clouds joining several spheres of different sizes and map the object with a tranz map.
bagginsbill posted Sun, 07 October 2007 at 11:24 PM
Quote - Or you can make clouds joining several spheres of different sizes and map the object with a tranz map.
Could you show an example? I've never had much success with that method, in terms of realism. What does this look like - what is the shader you use?
XENOPHONZ posted Sun, 07 October 2007 at 11:33 PM
Those are some of the best-looking Poser smoke plumes that I've seen.  Nice.  And useful.
Something To Do At 3:00AM
