ajmarti opened this issue on Sep 07, 2007 · 22 posts
ajmarti posted Fri, 07 September 2007 at 12:58 PM
Hi guys! I have 2 question in one!
Ok. I see so many seemless tiles stuff selling on the Marketplace. And i wonder
HOw do i use them on Poser?....i have many materials like leather and metals etc. and i apply them thru my Material Room on clothes and stuff.... but this TILES i have no idea. Can anyone tell me?!
I know is has something to do with Photoshop ... i have great knowledge of Photoshop but once i get these tiles can i use them let's say to change my clothes textures?? If so how do i used it
Same as those Merchant Resource for V3, M3 or V4.... there .jpg images.. am i suppossed to create one in Photoshop and apply it with the help of my Material Room piece by piece?????
Thanks so much!
AJ
Artist @ajmarti.com
momodot posted Fri, 07 September 2007 at 1:15 PM
The usual is to do the job in Photoshop although if you have Poser 5 or later you can play with the U and V scales in in the material setting of the advanced display node set ups.
I have corrected a number of purchased tiles so I can just tile them proceduraly. Thing is I have bought 4 or 5 tiling texture sets in the market place, so-called seamless textures, only to find that yes the border has been blurred to make the texture "seamless" but that there has been no effort to supress elements in the tile that show the repeate. I can't use any of them as tiles without fixing them or I have to paint the map with them in photoshop and clone/mend to hide the repeating elements. Then there are the market place fabric tiles and wallpapers I have bought, rather than align the image to repeat properly and uniformly, instead I find that they have placed a blur or fade running through important elements, perhaps they batch procesed the tiles to be seamles with a Photoshop filter rather than editing them "by hand".
Some vendors it seems think that the blur and fade of the tile edge make a texture "tiling" and "seamless", I don't agree... So far the vendors I have bought from have cropped tight "to protect" their samples from unauthorized use but this has also served to hide the defect of the products in all the purchases I have made, that the tile shows a pronouced repeat where it should not or a distorting repeat where the repeat should be regular such as a bouquette of flowers on a repeating wallpaper or cloth.
Acadia posted Fri, 07 September 2007 at 1:16 PM
If they are materials for Poser, you do it the same way in the material room, only to the ground.
If they are just plain seamless tiles I believe you can still use them in the material room. Only you have to right click in the work space, pick "new node" and then "2D" and then "image_map" and then browse to the material.
I have several seamless floor tiles from archibase.com that I use that way. You can adjust the size of the scaling that the tile is applied.
Or you can use them as flood fills when you are creating textures in your graphic program, or for web backgrounds etc.
say." - Ghandi
ajmarti posted Fri, 07 September 2007 at 1:38 PM
Great guys! i get it !
Thank you so much Acadia once again for helping me!
Momodot as i can se you're an expert on tiles... can you point me which one are your favorite here, some recommendations on the Marketplace ... some collection you think is the best i should start with?
Thank you guys you're great!
AJ
Artist @ajmarti.com
momodot posted Fri, 07 September 2007 at 2:10 PM
Attached Link: 3DDj`s Modular Materials Vol 3 : Naturals
I feel I have been failed by all those I have bought here, they all have required extensive editing before they can truly be used as tiles. I have had good luck with procedural textures from the MP but someone else will have to say what are good image based tiling textures.I did get a set of hybrid materials that were a combination of procedural and image mapped texture that was pretty good, 3DDj`s Modular Materials Vol 3 : Naturals.
The texturing .psd and brushes I bought were a disater and the layer styles I bought an even worse disaster. The .psd did not want to play well as layers, the brushes did not have good enough value distribution, and the styles can't be used with anything having more surface area then text selections because of the scale of the repeating elements, lay them on a box or cylinder and they look rediculous. All these products have required extensive editing to texture anything that needs actual tiling such as a rusted iron girder or a cloth curtain prop.
There are free proceduaral textures on the web that are terrific though, RuntimeDNA, and Mapps come to mind. Sorry no links right now.
Sorry to be a bummer but I just am so surprised that this sort of thing would pass as "seamless" in the RMP. These are my own negative examples above to show the idea, I did not want to violate copyright.
ajmarti posted Fri, 07 September 2007 at 2:50 PM
Hi Momodot!
Thanks again your help has beed wonderful! DOn't worry about the links....
Thank you!
AJ
Artist @ajmarti.com
mapps posted Fri, 07 September 2007 at 3:35 PM
There are some realy good seamless tiles in the free section.
Some of the good ones I have found are by;
lupadgds, AgentSmith, spacenewt and that mapps fella
http://www.renderosity.com/mod/freestuff/index.php?user_id=277463
http://www.renderosity.com/mod/freestuff/index.php?user_id=5875
http://www.renderosity.com/mod/freestuff/index.php?user_id=433359
http://www.renderosity.com/mod/freestuff/index.php?user_id=43772
ajmarti posted Fri, 07 September 2007 at 5:29 PM
Wow Mapps fella!!
Thanks you so much!....
i got so excite with your reply that i went to check the links before saying thank you! LOL!
Thanks for you help!
AJ
Artist @ajmarti.com
mapps posted Sun, 09 September 2007 at 11:00 AM
you are very welcome :-)
diolma posted Sun, 09 September 2007 at 5:38 PM
Acacdia said " You can adjust the size of the scaling that the tile is applied."
Absolutely right, and here's how, just in case you need to know...
Image Map 2 is just there to show how the texture comes in by default.
The connected image map has had its U- and V- scales set to 0.25 (1/4) thus fitting four images in the space of one. The result doesn't show up in the Preview, but does in the render (image at left).
Make sure that the "image Map" entry in the dialogue is set to "Tile" (It's the default, so it usually will be..)
This can sometimes also work for UV-mapped fabric textures but that can be prone to distortion - it depends on the mapping. However, for anything that is more-or-less square, it's usually good enough and saves mucking about with separate bitmaps...
Cheers,
Diolma
momodot posted Sun, 09 September 2007 at 7:01 PM
diolma, cool for showing that. I was too lazy but I am sure it is a help to people :)**
ajmarti posted Mon, 10 September 2007 at 6:50 AM
Now, that was great! Diolma THANK YOU, THANK YOU THANK YOU!!!!!!!!!!
That was exactly my confussion!....
Now i get the whole picture!
Guys you've help me to loose the "fear" to the Material Room with all this help
Thanks guys again! This is a wonderful Forum!!!!!!!!!!
AJ
Artist @ajmarti.com
mapps posted Mon, 10 September 2007 at 1:27 PM
well if you are feeling much more comfortable with the material room now you should also grab my free materials from the freesection. I ahve been told by many that by taking them appart it has helped them to understand many of the different nodes and what they do. :-)
ajmarti posted Mon, 10 September 2007 at 1:42 PM
Of course Mapps!
What a wonderful idea!.... well i already downloaded many of them!
But now that you mentioned this is a good moment for me to go shopping for free again, thanks to you!
Thank you my friend!
AJ
Artist @ajmarti.com
mapps posted Mon, 10 September 2007 at 8:35 PM
You are very welcome, there are also some great free mats at RDNA too :-)
ajmarti posted Tue, 11 September 2007 at 6:47 AM
Mapps i cannot thank you enough! i love it!....
i downloaded some of yours and try them and love it! LOL
Soon i'll be bothering you with more help!
AJ
Artist @ajmarti.com
mapps posted Tue, 11 September 2007 at 7:26 AM
you are very welcome, feel free to send me a "site mail" with any questions or help you may need. I'm always willing to lend a hand, though I don't visit the forums very often, so if you do post a question to me in the forums it is best to also send me a site mail letting me know to check out the forums :-)
ajmarti posted Tue, 11 September 2007 at 10:02 AM
And you're so cool!
This means a lot to me! And i will do that!
I don't visit the forum very often either.... i'm a Market Place addict!
So i'll send you an site mail!
Thank you, thank you, thank you!
AJ
Artist @ajmarti.com
mapps posted Tue, 11 September 2007 at 7:25 PM
Acadia posted Tue, 11 September 2007 at 8:18 PM
Here are lots of seamless tiles that you can use in the material room too.
http://www.gallerie1.de/html/architektur.shtml
say." - Ghandi
ajmarti posted Wed, 12 September 2007 at 5:29 AM
Acadia, you absolutely rocks! and Mapps you're the best!
I am so happy!
To think i was so confused with using the tiles but worse so afraid of the Material Room
I don't know why, but i felt like if i click on the wrong part it'll explode! LOL
But you guys are great!....
By the way, Pardon me if you see anything funny in my english... it's not may nature language!
Hugs and thanks my friends!
AJ
Artist @ajmarti.com
mapps posted Wed, 12 September 2007 at 6:16 AM
You are very welcome :-) I am always impressed by someone that can spaeak and read more than one language, and anyone who learns English as a second language has my sympathy...it is the most messed up language on the planet :-) (I only speak and read English, and a little bit of French)
