JohnMalv opened this issue on Sep 09, 2007 · 3 posts
JohnMalv posted Sun, 09 September 2007 at 5:43 PM
I can't seem to create a rectangle layer on any object originating from the vertex modeling room. It works fine on primitives added from the assembly room however. I thought maybe it had something to do with uvs but I tried every possible combination of uv mapping and still no results. Adding shading domains didn't help. I even converted the primitive to a vertex object in the vertex room and it received the rectangle layer just fine.
Any ideas? Is this a bug or operator error? I'm hoping for operator error actually.
One other thing: while in the shader room, if I switched the preview to "Sphere" (instead of the actual vertex object), I could then draw and manipulate a rectangle on the sphere. If I switched back to the vertex object view, the rectangle would be there but was not resizeable or moveable.
Any help appreciated
John
thomllama posted Sun, 09 September 2007 at 7:13 PM
having the same issue!! read above post, didn't even think of trying a privative.. my object was done in Hexagon then imported to carrara... so anything vertex can't be "drawn" om I guess. unless it has to do with vertex models having UV?
anyone?
Hexagon, Carrara, Sculptris, and recently Sketchup.
JohnMalv posted Sun, 09 September 2007 at 7:43 PM
I got an answer on the DAZ forum that this is a bug and has been reported. Let's keep our fingers crossed and hope it gets fixed in the next release.
