Subject: Poser Tubes
Hamiltongraphics opened this issue on Sep 10, 2007 · 3 posts
Hamiltongraphics posted Mon, 10 September 2007 at 6:51 PM
What are poser tubes.  I see them in freebies and other places.  Thanks in advance, Jim
Acadia posted Mon, 10 September 2007 at 7:06 PM
They are just a rendered image, usually a single item such as a figure, plant, table etc, that is saved as a .png file which has no background. Thus it can be copy/pasted to any background.
The term "Tube" actually comes from Paintshop Pro where a "tube" is an actual file format known as .tub. Images are imported to the Tube Tool and are then applied using that tool.  I only use the tube tool in PSP for things like creating strings of pearls or when I want to make strings of images.
The term also applies to any isolated image that has no background, such as an image where a portion of it was cropped out and saved on it's own without a background.
hewee posted Tue, 11 September 2007 at 8:12 PM
If you got PhotoImpact you can use them as Stamps or you can import tubes and use as Stamps.
They work just like tubes.
