TerraMatrix opened this issue on Sep 22, 2007 · 5 posts
TerraMatrix posted Sat, 22 September 2007 at 4:51 AM
First off, the scene I'm trying to create is like the Burly Brawl from The Matrix Reloaded. There are a lot of figures, in many different positions all interacting with each other, so simple replication is not a solution. I'm not sure if proxy is the right term, but what I'd like to do is have very simple, low-rez figures that I can position in the scene, that will then be replaced by the real figure at render time. Could this be possible through scripting (which I know nothing about, sadly), or might this be more a thing for one of the pro programs like Max (assuming Max can do it)?
ominousplay posted Mon, 24 September 2007 at 2:02 AM
There is a plug-in for this around some where... but for multiple figures, and without the plug, try 10 different poses of the same Agent Smith, and use the replicator - I've had success with five poses of a bird, then replicated in a flock flying - I even used animation. You're looking to make an animation or just a still?
Never Give Up!
ominousplay posted Mon, 24 September 2007 at 2:07 AM
Inagoni sells Replica and Swap - check that out too.
Never Give Up!
TerraMatrix posted Wed, 26 September 2007 at 9:58 PM
Thanks, I'll look into those!
At this point, it's probably just going to be stills, but with figures positioned far above the ground, as well.
bwtr posted Wed, 26 September 2007 at 10:01 PM
