Forum: Carrara
Subject: Cannot move objects in C6pro.
JOEANOMALY opened this issue on Sep 22, 2007 · 5 posts
JOEANOMALY posted Sat, 22 September 2007 at 6:29 PM
I've recently upgraded from C5 to C6pro.I tried to create a scene and discovered that I cannot move objects(i.e. mountains, water, etc.) Could do it just fine in C5. Why???
  Can someone, please help?
keithw posted Sat, 22 September 2007 at 7:13 PM
Could it be that your Caps Lock key is on. I just spent over an hour trying to move an obect using the move manipulator tool.  the hot point would move but the object wouldn't.  Then I noticed the Caps Lock key was on. I turned it off and move tool worked fine.
I hope this solves your problem.
Keith
JOEANOMALY posted Sat, 22 September 2007 at 7:19 PM
That sounds crazy enough to work. I' ll try it. Thank you!
JOEANOMALY posted Sat, 22 September 2007 at 7:27 PM
It worked, i'd never of thought the capslock would interfere with the object moving thing. Thanks again, keithw!
Hoofdcommissaris posted Sun, 23 September 2007 at 7:02 AM
With the capslock on, you can move the hotpoint of an object, which sometimes comes in very handy.
