NemesisT opened this issue on Sep 23, 2007 · 10 posts
NemesisT posted Sun, 23 September 2007 at 4:20 AM
Hi,
I just made a smart prop (my first, modelled in hex ) but I can't seem to texture it in poser.
If I add a texture as normal it will still turn out grey. Any idea what I
might have missed ?
Sara
pjz99 posted Sun, 23 September 2007 at 4:35 AM
How exactly do you mean, "add a texture as normal"? What steps are you taking exactly?
jonthecelt posted Sun, 23 September 2007 at 4:49 AM
Before bringing the prop into Poser, did you UV map it in Hexagon? Whitout the UV infomratino, then textures won't be applied correctly to your objects.
JonTheCelt
NemesisT posted Sun, 23 September 2007 at 5:27 AM
I uv mapped it in hex and textured the map
then I go into the material room in poser and add the texture
as an image map as I would normally do. But yet it
comes up grey.
NemesisT posted Sun, 23 September 2007 at 5:49 AM
Oh and it did show up before I added a parent to it and saved it as a prop
pjz99 posted Sun, 23 September 2007 at 6:45 AM
Quote - then I go into the material room in poser and add the texture
and what you would normally do is......... Have you tried importing the OBJ and simply saving it as a prop directly first, and then load the prop from the library?
vincebagna posted Sun, 23 September 2007 at 7:25 AM
Quote - Oh and it did show up before I added a parent to it and saved it as a prop
When you UVMapped it in Hex, did you create the material names first? When you try to apply your map in Poser, do you have the choice between several texture domains?
Acadia posted Sun, 23 September 2007 at 9:36 AM
Maybe try "normals forward" in the material room?
say." - Ghandi
Stepdad posted Sun, 23 September 2007 at 10:51 AM
Have you used posers group editor feature to assign material groups to the various sections of your prop?
That would be my first guess... if your needing more detailed instructions on how this is done let me know and I'll see if I can't put together a real short tutorial on the subject.
lululee posted Sun, 23 September 2007 at 11:20 AM
Do you have the item it is smart propped in the scene? If not that might be the problem.
cheerio lululee
