tkane18 opened this issue on Sep 28, 2007 · 16 posts
tkane18 posted Fri, 28 September 2007 at 10:26 AM
Paloth posted Fri, 28 September 2007 at 11:31 PM
I suspect that the graininess is in some way connected to the high-speed defaults in Carrara 6. If you're after high quality you'll have to slow to Vue-like speeds.
tkane18 posted Sat, 29 September 2007 at 12:08 AM
Even when I increased the quality, it didn't look like the C5 render.
In fact, it takes on a very waffle-like appearance.
MarkBremmer posted Sun, 30 September 2007 at 8:29 AM
I haven't been able to reproduce this but I think it's related to the new scaling in C6. C5 had one size only for it's environments. However, C6 now has three. Can you share what your settings are and I'll see what I can figure out. Mark
tkane18 posted Sun, 30 September 2007 at 8:21 PM
Here's the file if someone wants to take a crack at it.
bwtr posted Sun, 30 September 2007 at 8:37 PM
Don't think you can make the .car file available that way? Not in a zip at this forum either I think.
bwtr
MarkBremmer posted Sun, 30 September 2007 at 10:01 PM
Got it. I'll take a look tomorrow. Mark
bwtr posted Sun, 30 September 2007 at 10:59 PM
I got to download the file!
REALLY awaiting Marks answer.
That C5 file is grainy in any of the screen "Size" versions renders in C6. I swapped the sky with a new realistic in C6--same result--grainy?
It's a big worry I think that all those, many, C5 files (OF MINE!) may also not be able to be properly worked on in the future in C6?
What else may be effected in all my many C5(and older) file saves?
bwtr
MarkBremmer posted Mon, 01 October 2007 at 8:23 AM
Definitly something funky. It is tied to the scale/magnitude of the scene but I don't have work-around yet. There are some illogical numeric relationships that when adjusted, blow up the scene. tkane18, can I have your permission bundle this up and get it over to DAZ? Mark
tkane18 posted Mon, 01 October 2007 at 8:43 AM
I tried to scale the clouds with the different scene scales/magnitudes and still got the same results.
Mark, go ahead and send that off to DAZ. That was going to be my next step anyway but it might get more attention coming from you.
Thanks for the responses.
MarkBremmer posted Mon, 01 October 2007 at 9:04 AM
And away it goes... :D
mykyl posted Mon, 01 October 2007 at 3:37 PM
All they will say is its meant to be like that.
They will then say 'Use large scale from the start as thats what its for...' etc etc etc. Pretty much all I got back for each issue I pointed out. Needless to say I dont expect anything good from the patch as 'thats the way its meant to be' type crap. Still dont like the 'extra' work for the bones in Carrara 6 and doing the bones in 5 and importing to 6 is not any better but.. 'Thats the way its meant to be and if you do about 500 extra things you can get it to look like it used to... hmmmm.
Anyone would think I was unhappy. ;)
Cheers
Mike R
DerkDorsten posted Fri, 05 October 2007 at 3:50 PM
fpfrdn3 posted Fri, 05 October 2007 at 4:12 PM
I will be watching this thread closely, as I will be doing some heavy cloud renders and landscaping with C6. By any chance, could this grainy effect be related to multi CPUs and C6? Maybe try render with just one core(maybe way off, worth a try?...I only have single core so I can't test).
MarkBremmer posted Fri, 05 October 2007 at 4:30 PM
If everything is authored in C6, it's not a problem. At this point, it's only an issue if you are importing a C5 scene.
tkane18 posted Wed, 10 October 2007 at 3:38 PM
As you can see in my screenshot, this is the same C5 file open in C6 with the only change being the Z scale parameter. I'm happier now that I have figured it out. Just something to be aware of.
