Indoda opened this issue on Sep 29, 2007 · 30 posts
Indoda posted Sat, 29 September 2007 at 11:18 AM
Hello all, There is, IMHO, a need for a review/list of programs that support Poser in some way. I see the odd message Help with . needed or is it worth buying xyz.exe There are a number of older programs that do not really work that well with the later Poser versions but may be fine with P4. Does anyone else think that this would be a useful thread? To start the ball rolling: PhilC - Wardrobe Wizard - great program - great support PhilC - Cloth Designer - excellent for learning to make clothing with out having to use a 3D editor, OBJ2CR saves time and gets your cloth onto the character, you still need to tweak the joints, very well supported. CRPro - has started to truncate files and wants to change all "NO_MAP" to file"" No update ? Abandon ware? AutoGroup Editor - almost no support -very perculiar middle mouse button operation for rotating, panning etc.. Morph Magic - Some say it works others say it doesn't! Dimension3D Toolkit - seems stable and does the job it's supposed to - not sure about the interface Dimension3D Poser Organizer - same type of interface as the toolkit I'll leave it at that for now ~ there are times when I feel that some of the products that are recommended are not very well supported by the author/or vendor and one can easily spend a great deal of money on tools that actually are more frustrating than need be. Climb in and either defend your favourite tool, recommend its features, ease of use etc, or tell of disappointing purchases. Please keep it civil, Thank you, Indoda
The important thing is not to stop questioning.
- Albert Einstein
Indoda
dphoadley posted Sat, 29 September 2007 at 11:53 AM
UV Mapper Pro (by Steve Cox): As far as I know, this is the best UV Mapping tool extent.
MorphManager (Freeware): Simply magic for transferring morphs from one character to another, based on the same figure object.
Cr2 Editor (Freeware): Great for doing Cr2 edit work that Morph Manager cannot do.
DPH
FrankT posted Sat, 29 September 2007 at 1:33 PM
vue 6.5 to do the rendering :)
steveshanks posted Sat, 29 September 2007 at 1:44 PM
AutoGroup Editor, Dimension3D Toolkit, UVMapper, are 3 apps i just couldn't manage without..........Steve
wheatpenny posted Sat, 29 September 2007 at 1:49 PM Site Admin
Lightwave, 3dsMax or wings for modeling
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Miss Nancy posted Sat, 29 September 2007 at 3:02 PM
cs3 c6pro
nickedshield posted Sat, 29 September 2007 at 3:03 PM
Here a few I use, some already mentioned: UVmapperPro AutoGroup Editor Dimension3D Toolkit Cr2editor MorphManager Mover RTEncode/Decode MatPose Edit Wardrobe Wizard Cross Dresser the Tailor Hex for modelling Universal Texture Converter P3do Explorer Out side of Wardrobe Wizard the others listed are stand alone apps. leaving out all of the specialty python scripts that may be version dependant.
wdupre posted Sat, 29 September 2007 at 3:09 PM
Easypose Underground - excellent tool for all sorts of editing of joints and morphs and ERC connections, as fast and easily as possible. Very well supported by Ajax. I find uses for it on every project I do these days. http://www.runtimedna.com/mod/bcs/index.php?ViewProduct=2881&TopID=162808 cr2 Builder - Free cr2 editor similar concept to cr2 editor but much more robust with many more features. this is my go to cr2 editor http://www.geocities.co.jp/Bookend-Ohgai/9483/tool/CR2Builder/index.html Phi Builder - latest version is nearly 10 years old I believe, but still the easiest tool to create Phi files for complex rigs. http://www.royriggs.com/poser.html Tool Collection - another vote for this awsome set of tools for content production. another package I use on every project. http://www.renderosity.com/mod/bcs/index.php?ViewProduct=37406 Edit Pad Pro - I know this is more of a generic text editor but it has some amazing features built into it and gets used constantly in my production. particularly the ability to do batch processes. like search and replacing multiple lines of text on dozens of files at one time. http://www.editpadpro.com/
Conniekat8 posted Sat, 29 September 2007 at 3:11 PM
oooh, this would be a great addition to the sticky thread we have going in here, about making your own poser clothes!
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
SamTherapy posted Sat, 29 September 2007 at 3:15 PM
Echoing votes for Wardrobe Wizard and UVMapper Pro. Excellent pieces of kit and first class support.
Bobbie25 posted Sat, 29 September 2007 at 3:39 PM
On uvmapping I'm uvlay out all the way and i do have uvmapper Uvlay out easy to learn fast to use has so many vid tuts you cant mess it up lmao.
Morph Designer is a good tool for adjusting your motphs a little more
Typing Advisory :
Read at your own risk! May cause
dizziness, naseua,drooling, and temporary blindness.
Surgeon General recommends running the txt through a spell
checker.
SamTherapy posted Sat, 29 September 2007 at 3:41 PM
Quote - On uvmapping I'm uvlay out all the way and i do have uvmapper Uvlay out easy to learn fast to use has so many vid tuts you cant mess it up lmao.
Whut?
operaguy posted Sat, 29 September 2007 at 4:08 PM
Quicktime Pro - easy, powerful way to assemble your folder of frames (image sequence) into an animation, then save out to codex/compression.
After Effects for animation post processing
EditPlus (fantastic text and html editor)
http://www.editplus.com/
and last but not least....
Canvas (ACD) ...which I am sure no one else has heard of, uses or would purchase (because there are a lot of free and low cost 2D apps). You don't need Canvas Ten...Canvas 8 is all you need, works for Mac and PC.
http://www.deneba.com/buy/dr_store/product_list.html
I'm putting this link because it memorializes a very great, very flexible competetor for Photoshop that ALSO is a 'painter.' In many ways it is better than PS. It can also import a folder of frames and make animated gifs.
geoegress posted Sat, 29 September 2007 at 4:21 PM
Blacksmith paint 3d (freeware version) has great potential- If I can ever figure out the interface and terminalogy. As of now the tuts and instructions really need explaining.
Indoda posted Sat, 29 September 2007 at 4:56 PM
Oh good - we're off to a good start - add some comments to the apps if you can. @dph - silly me forgetting UVMapper (smack) @geogress - If you need help with Blacksmith3D I can try and help you @wdupre - cr2 editor - I've got to check the link for Cr2 builder not sure I've seen that one @Operaguy - forgot the movie makers - thanks for your additions @Conniekat - could be a sticky I'd like to see more of an organised list of programs and what they are used for so that we build a informative and helpful list for new and old users who are trying to extend their Poser experience @Bobbie25 - I almost echoed SamTherapy but I think I understand @others The Tailor is still a bit of a mystery to me anyone ever written an easy to understand tutorial? I missed some of the most obvious off my list LOL Mind goes blank every now and then ;) UVMapper, Mover, RTEncoder, PD3 Explorer and my favourite Advanced Library by Dizzi Thanks guys, keep them coming Indoda
- Albert Einstein
Indoda
diolma posted Sat, 29 September 2007 at 6:23 PM
It was mentioned just once in a list above, so I'll mention it again:
P3DO explorer.
For finding out where those wretched textures are hiding (and other things).
Cheers,
Diolma
Morgano posted Sat, 29 September 2007 at 6:35 PM
UVLayout, which Bobbie25 mentioned, is here: www.uvlayout.com/
I can't comment on it, having never used it, but Xena mentioned that she preferred it to UVMapper (thread called "Any Sugestion about a tool set to create clothes for poser??").
dlfurman posted Sat, 29 September 2007 at 7:05 PM
Attached Link: http://www.uvlayout.com/
> Quote - > Quote - On uvmapping I'm uvlay out all the way and i do have uvmapper Uvlay out easy to learn fast to use has so many vid tuts you cant mess it up lmao. > > Morph Designer is a good tool for adjusting your motphs a little more > > > > Whut?
There is a program called UVLayout and there are video tutorials you can d/l to see how the program works. I love it myself (I used the beta test version. Helped me to make a truly symmetrical uvmap of the V3 Ultra Catsuit. I just wish I had the $$ to pick up the release version)
Version 2 is out and has demo
space
Dale B posted Sat, 29 September 2007 at 7:37 PM
And to add to Opera's .... Particle Illusion 3 (and if you have After Effects, the upcoming PI plugin) Audition for all your sound editing needs. Sonic Fire Pro for your musical scoring Premiere Pro for your video editing needs. Scriptwriter Pro for your script creation and scene mapping needs.
Conniekat8 posted Sat, 29 September 2007 at 7:48 PM
Quote - @Conniekat - could be a sticky I'd like to see more of an organised list of programs and what they are used for so that we build a informative and helpful list for new and old users who are trying to extend their Poser experience
That would be really nice to pull together, and mau help the admins with updating the FAQ's around here. It's something they said they need help with.
In any case, I put a link to this thread in the other one (since it's sticky). There's a lot of good info in here, and it keeps coming. I'd hate for it to get lost :)
yurs?
BadKittehCo
and product support
odeathoflife posted Sat, 29 September 2007 at 9:02 PM
Well this is what I regularly use in conjuntion with Poser (7)
hexagon (I have trueSpace, AmapiPro, Silo1.4 that I have tried and Carrara Standard that I havn't got to yet but hex just speaks to me) for modelling
RoadKill1.1 (I have uvmapper free, tried UVLayout and would use this is I was rich LOL) but this is free and powerfull and based on Blender's UVMapping so it is OpenSource.
EasyPose Underground 1 (never tried the new version...and got this one for beta'ing the pWizard addon) and truly a great program.
OBJ2CR2 - fantastic cr2 maker...but do not use it much anymore with Poser 7 on the box...the NFR copy I have is for Poser 6
VFBasic (no flames please but this is a good proggy for what it does)
I do have a few more that I do regulary use but these are the ones that I can not see not using.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
pakled posted Sat, 29 September 2007 at 9:36 PM
dang, everything I can think of is already named..;) Suppose I could mention Wings does UVMapping (which I have a nodding understanding of..;), as does Blender (blender does just about everything, once you find which one of a jillion menus it's in..;)
just to get my noggin knocked..there's a sticky or 2 in the Freepository forum at Daz of various proggies to use...if you want a few more.
SoCalRoberta posted Sun, 30 September 2007 at 12:16 PM
ColorPic, GenoSwatch2.1, and ColorCop.
All freeware.
Very useful for work in the material room and textures.
Acadia posted Sun, 30 September 2007 at 12:47 PM
Here is my list:
Wardrobe Wizard
Ockham's Scripts
Dimension3D Easy Pose
UV Mapper
Mat Pose Edit
Spanki's Stomp (Sorry, I can't find a current link )
The Tailor
Ivy Generator
Poseray
RTEncoder
Universal Texture Convertor
Objaction Mover
Here is another thread on this subject from a few months ago:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3027258
say." - Ghandi
seadog posted Sun, 30 September 2007 at 5:44 PM
I hope this does become a sticky. Furthermore, I hope that each of the programs are listed by catagory (like UV Mapping programs, etc.). :)
seadog posted Sun, 30 September 2007 at 6:09 PM
Oh and maybe a note (an astrix or something) next to the proggies that are free. :)
EnglishBob posted Tue, 02 October 2007 at 4:07 AM
Acadia, STOMP can be downloaded from here: Spanki's Prop Shop - go to Downloads, then Utilities. I have my own list of Undoubtedly Useful Utilities. :)
Gini posted Tue, 02 October 2007 at 8:52 AM
Quote - I hope this does become a sticky. Furthermore, I hope that each of the programs are listed by catagory (like UV Mapping programs, etc.). :)
It would also be super helpful if each could be noted as PC only or Mac/PC compatible . I'm sure other mac users find it very frustrating as I do to get all excited about a really useful sounding utility , follow a link, finally find the page that has system requirements .only to find it a PC ONLY proggy. Grrr.
" Try and be nice to people, avoid eating fat, read a good
book every now and then, get some walking in, and try and live
together in peace and harmony with people of all creeds and
nations."
-Monty Python
renderclipps posted Thu, 25 October 2007 at 1:04 PM
I'm looking for a plugin to increase my video codec options when i'm making a poser movie
Ideally DV
I find then microsoft video 1 terrible quality plus I'm having problems when I export an uncompressed video to Premier CS3
Any ideas welcomed
fls13 posted Thu, 25 October 2007 at 2:33 PM
Compose-for manipulation of .obj file, great for morphing
Poseray-converts Poser files to Povray usage
Programmer's File Editor-great for the text hacking of files
All free!!!
