Subject: How do you turn off texture filtering?
seattletim opened this issue on Oct 01, 2007 · 5 posts
seattletim posted Mon, 01 October 2007 at 9:35 AM
I am on Poser 7 and am working to get more realistic renders. I heard this was important to do - but I can not see where to do it in the render options. Any advice? Thank you.
Tyger_purr posted Mon, 01 October 2007 at 9:47 AM
it is not important to do.
if you have blurry textures in poser 7 you should lower your "min shading rate" in your render settings.
In poser 6 this blur was commonly caused by texture filtering but they changed the way poser handles texture filtering and they moved the texture filtering into the individual material zone.
 the biggest problem is that they also set the default 'min shade rate" to 1.0 (perviously 0.2 i beleive) in poser 7. Many people didn't pay attention to this setting and assumed that texture filtering was the problem.
My Homepage - Free stuff and Galleries
ockham posted Mon, 01 October 2007 at 10:50 AM
Tyger_purr:  By jiminy, you're right.  I wasn't paying much attention to the Shading Rate, because I'd seen that cutting the filter made a good difference. But I just now tried it all four ways, and clearly it's the shading rate that makes the *REAL* difference!
My python page
My ShareCG freebies
Miss Nancy posted Mon, 01 October 2007 at 12:44 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=2861782&ebot_calc_page#message_2861782
see attached link at attached link
sixus1 posted Tue, 02 October 2007 at 12:15 AM
In the material room, Select the material zone on the figure that you want to change...at the bottom of an image node, there is an option for 'filtering' with the options of None, Fast or Quality.  Select 'None'.
