Reddog9 opened this issue on Oct 03, 2007 · 5 posts
Reddog9 posted Wed, 03 October 2007 at 5:56 PM
Anyone no how to set this up? I was going to work on a music video, and thought I'd pan some of the work load off on my lap top. I've searched the Blender docs but have been unable to find it. I'm sure I saw this listed as a Blender feature somewhere.
Scott
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
l3la posted Mon, 08 October 2007 at 1:27 AM
If you don't have time to learn to setup one of the network rendering systems you can just use the command line version of Blender to render a few frames on each computer and manually queue up more when each computer is done.
http://wiki.blender.org/index.php/Manual/Rendering_From_Command_Line
If you have a little money you should use this service:
http://www.respower.com/
Or if you have time you an learn to setup one of these systems:
http://www.blendernation.com/2006/12/13/more-distributed-rendering-options/
Reddog9 posted Mon, 08 October 2007 at 8:56 PM
Thanks for the info. I looked back and apparently I was mistake, it's not a built in feature. Bryce has an included app for rendering over a network which I've used before.
I'll try to set one up.
Red
Reddog9
l3la posted Tue, 09 October 2007 at 6:11 PM
You're welcome. Just in case someone else wants to try the quick and easy way:
I used this type of command line before:
blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 001 -e 050 -a -x 1<br></br><br></br>and on the second computer:<br></br><br></br>blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 051 -e 100 -a -x 1<br></br><br></br>and so on depending on how many computers you have. <br></br>When one finishes just repeat the command with different frame numbers. <br></br>If one computer is slow you can just kill the process, re-assign the leftover frames and take whatever frames it has already done.
DramaKing posted Tue, 06 November 2007 at 5:30 PM
I know this is an old thread, but I've started using a Blender version called verse-blender. It's listed on Blender.org in the Download section. Under Scene < ANIM, click Render Daemon. There's also a script called Farmerjoe that will also give net render capability. You'd have to do a web search for it, though.
It is better to do one thing well, than to do many things and excel at nothing.
