Forum: Carrara
Subject: Importing Illustrator files
baldknees opened this issue on Oct 05, 2007 ยท 8 posts
baldknees posted Fri, 05 October 2007 at 3:00 PM
Uh oh! When trying to import an Illustrator CS2 file into the spline modeller, C6Pro tells me it's an incompatible format, and can only import up to Illustrator 8 version!!!
Surely not... Illustrator 8 was in play 5 or 6 years ago?!
Anyone figured this one out yet?
MarkBremmer posted Fri, 05 October 2007 at 3:15 PM
Just do a "Save As" from within Illustrator, select the ai8 format and you'lll be fine. Mark
baldknees posted Fri, 05 October 2007 at 3:41 PM
Thanks Mark. I think that means I have a problem, as it appears I need Version Cue to get addidtional formats for saving!
I have CS2 Illustrator as a stand-alone, and not as part of the Creative Suite, and am only given the option of saving in .ai format.
Eish!
baldknees posted Fri, 05 October 2007 at 4:04 PM
Mark, I've just dug out and shaken off several years of dust on my copy of Illustrator 6! I've installed it and can import those .ai files. Bit of a bollock breaker though, as it's OS9. Technology... you gotta love it!
Thanks again.
bwtr posted Fri, 05 October 2007 at 8:20 PM
CS2 Illustrator can save in all the older AI file versions.If you click on the right save item you get a dropdown from which you select the AI version.
bwtr
baldknees posted Sat, 06 October 2007 at 2:43 AM
Of course! Sorry! In my defence, I'm a Photoshop jockey, and just getting to grips with a little bit of Illustrator... lame, I know!
Thanks for your indulgence!
(Good thing this site's colour is blue... it helps to disguise the red glow from my face...)
bwtr posted Sat, 06 October 2007 at 3:01 AM
If you dont say -------b---------- or go purple in the face several times a day you are not working in CG or 3D!
bwtr
baldknees posted Sat, 06 October 2007 at 3:25 AM
lol
Is that why you wear the purple hat?
