BecSchm opened this issue on Oct 08, 2007 · 10 posts
BecSchm posted Mon, 08 October 2007 at 10:35 PM
Apologies if this has been asked before!
stewer posted Mon, 08 October 2007 at 11:08 PM
Attached Link: http://www.poserfashion.net/tablecloth.htm
Here's a table cloth.BecSchm posted Mon, 08 October 2007 at 11:10 PM
Thanks! Just what I needed!
ockham posted Mon, 08 October 2007 at 11:15 PM
Attached Link: http://ockhamsbungalow.com/MiscProps/Skirt-flat.zip
This might or might not be better than the one you've got....It's UV-mapped cylindrically so that weaves will look right, I think......
BecSchm posted Mon, 08 October 2007 at 11:30 PM
These both work great - thanks for the links -
Lucifer_The_Dark posted Tue, 09 October 2007 at 5:35 AM
You could also use the High res ball prop included in poser, just change the z scale to 1 or 2 & you have your round disk :D
Windows 7 64Bit
Poser Pro 2010 SR1
EnglishBob posted Tue, 09 October 2007 at 6:34 AM
Quote - You could also use the High res ball prop included in poser, just change the z scale to 1 or 2 & you have your round disk :D
This probably won't work very well, unfortunately. The cloth room doesn't like double sided meshes.
SamTherapy posted Tue, 09 October 2007 at 8:23 AM
You could, however, use the Grouping tool to create a prop from one end of a cylinder.
EnglishBob posted Tue, 09 October 2007 at 8:48 AM
SamTherapy posted Tue, 09 October 2007 at 9:40 AM
Yeah, you're right there. I'm used to creating primitives in UVM Pro these days. I forgot about the naff ones in Poser.
