wrpspeed opened this issue on Oct 12, 2007 · 10 posts
wrpspeed posted Fri, 12 October 2007 at 9:47 PM
I was wondering if anyone has had any problems (with p6) after the october 10 xp security
upgrades? After the upgrade and p6 is running, it folds if you try to open or save a
document. When i use system restore to back the security upgrade out, poser 6
runs normal again. poser 5 is unaffected. I was wondering if anyone else is experiencing
this?
cspear posted Sat, 13 October 2007 at 7:57 AM
Just tested this: no problems here.
PoserPro 11 - Units: Metres
Adobe CC 2017
nruddock posted Sat, 13 October 2007 at 8:10 AM
What can happen with these updates is that the OpenGL version gets reset to the default Microsoft one.
The solution if this is the case, is to reinstall the lasest drivers for your card.
vincebagna posted Sat, 13 October 2007 at 8:16 AM
I noticed no probs here.
pakled posted Sat, 13 October 2007 at 10:45 AM
..and this is why I keep the upgrades 'off'...;) sorry to hear about that, but I've been burned once too many times by things like that.
There is a way to turn off automatic upgrades, I did a search on the net. You have to make a hidden ini file visible, edit out a line, and then a couple other things. If you're interested...check it out.
Acadia posted Sat, 13 October 2007 at 11:37 AM
No problems here.
While I have my system set to automatically download the updates I always pick "advanced install" and pick and choose what to install.
MS always wants to install some malicious remover thing. I have no idea what that is but I don't want anything on my computer that automatically removes anything without me knowing about it. So I never let that install.
Anyone know what that malicious remover item is that they want to install is about?
say." - Ghandi
nruddock posted Sat, 13 October 2007 at 11:44 AM
Attached Link: http://www.microsoft.com/security/malwareremove/default.mspx
> Quote - Anyone know what that malicious remover item is that they want to install is about?Mostly Harmless.
Acadia posted Sat, 13 October 2007 at 11:49 AM
Thanks :) I see that it runs in the background which means eaten up resources. I think I'll pass. I already have my virus scanner running so that should be enough.
say." - Ghandi
Khai posted Sat, 13 October 2007 at 12:10 PM
Quote - ..and this is why I keep the upgrades 'off'...;) sorry to hear about that, but I've been burned once too many times by things like that.
or you can simply turn them off in Services or in the Control Panel / System.. why all the making hidden files visible etc? man thats making work for yourself ;)
wrpspeed posted Sat, 13 October 2007 at 3:59 PM
i can tell you that malicious remover is not causing the problem as I unchecked that
when installing the software update and the problem did not stop so I concluded
it was in one of the 1st 3 security updates.
