Subject: Odd error in P7 animation.
Torulf opened this issue on Oct 14, 2007 · 7 posts
Torulf posted Sun, 14 October 2007 at 11:52 AM
I make an animation in Poser7. AVI 25 f/s .It becomes jumpy because every time step is 30 frames not 1 frame. I got 30 times more frames than I need. I have tested several settings and got same result. Watt is I doing wrong?
TG
Touchwood posted Mon, 15 October 2007 at 12:32 AM
Can you give some more information? Do you mean that the default length is 300 frames instead of 30. Do you have skip frames turned on (silver dot) or off (no dot). what happens when you click on the step forward - step back buttons. Does it move one frame or more.
Miss Nancy posted Mon, 15 October 2007 at 1:41 PM
1 key frame every 30 frames? jumpy during playback in posrr, or jumpy during playback in video player?
Torulf posted Mon, 15 October 2007 at 3:21 PM
Jumpy during playback in video player! In poser everything looks normal.
TG
Miss Nancy posted Mon, 15 October 2007 at 7:21 PM
this implies the data rate (KB/sec) is too fast for the machine on which the video player is being run.
Torulf posted Mon, 15 October 2007 at 9:49 PM
How shal I sett the data rate?
TG
Miss Nancy posted Mon, 15 October 2007 at 10:45 PM
decrease rendered video size to 320X240 pixels. if this is still jumpy at 25 fps, then a new graphics card/CPU is recommended. alternatively, it's possible to adjust the data rate of the converted video in some software, e.g. DivX Pro et al.
