tastiger opened this issue on Oct 16, 2007 · 5 posts
tastiger posted Tue, 16 October 2007 at 3:27 PM
I took the plunge and upgraded my system to an AMD X2 5600, 4 gig ram, Geforce 8600 GT and Vista Ultimate 64.
Hoping some of you out there can share your experiences on render setting when using a fairly high end system.
I have really noticed the difference in render times with Carrara - but not so much with Poser - so I'm guessing it's my render settings....
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
pjz99 posted Tue, 16 October 2007 at 3:44 PM
64-bit vs 32-bit will not greatly improve render times - benchmarks I have seen for Vue (Louguet) are around 1-2% increase in speed, if any. The advantage is effectively unlimited memory usage for apps that are written in 64-bit instructions - and Poser is not one of those. It's not a really big benefit in Poser, although it's great for Vue, Cinema 4D or Max or any of the other "big boy" apps.
Khai posted Tue, 16 October 2007 at 4:09 PM
and Poser is not one of those. - Qualifyer 'Yet' (Poser Pro II is supposed to be 64bit rendering, but has not been released as yet)
stewer posted Tue, 16 October 2007 at 6:59 PM
Poser 7 is compiled as "large address aware", so it will get a full 4GB address space on your 64 bit machine. I recommend enabling rendering in a separate process, then the renderer will get its own separate 4GB address space as well as setting it to render in 4 threads to maximize the usage of the two CPU cores. And congratulations to your new machine!
tastiger posted Tue, 16 October 2007 at 10:33 PM
Quote - I recommend enabling rendering in a separate process, then the renderer will get its own separate 4GB address space as well as setting it to render in 4 threads to maximize the usage of the two CPU cores. And congratulations to your new machine!
Thanks - that is just the information I was looking for...
:b_grin:
it alive.
Robert A. Heinlein
Windows 11 Pro
