colorfulsilk opened this issue on Oct 17, 2007 · 8 posts
colorfulsilk posted Wed, 17 October 2007 at 8:07 AM
Hello all,
I just want to know how do you use conforming hair and clothes in DAZ Studio?
Thanks
RHaseltine posted Wed, 17 October 2007 at 8:16 AM
Select the clothes or hair after loading (the root of the item, with its name, if you are selecting in the Scene palette or double-click in the viewport) and then use the Fit button in the Parameters palette, or right-click(Win)/control-click(Mac) on part of the item in the viewport and select Fit to... from the context menu. Pick the figure that should be conformed to from the list, click Accept if you used the right-click method.
colorfulsilk posted Wed, 17 October 2007 at 1:55 PM
Thanks alot RHaseltine.
missykia posted Sun, 30 March 2008 at 7:34 PM
What if the fit to button still doesn't do it? Like mine, It usually works, but lately on A3
I can't get any clothes to fit her right at all.
That is why I'm here I am looking for clothes. :)
RHaseltine posted Mon, 31 March 2008 at 10:04 AM
Did you have morphs applied to the figure? Fitting doesn't chnage the shape of the outfit directly, though if there are morphs on the clothes that match those on the figure (in name) they will take the corresponding values.
missykia posted Mon, 31 March 2008 at 10:30 AM
Thank you for your fast reply. I use Aiko 3 her morphs and Krissy Character and morphs.
When I don't use the morphs her clothes will fit.
xo
Are you saying if i use lets say just aiko and her morphs, that i can't use the clothe i use on her without her morphs? And when I use aiko and her morphs and a character and her morphs i need spesial clothes ?
One more question :) do i need to use the character and morphs with aiko and her morphs on her , or am i supposed to use only one morph at a time. Still a little confused in this area.
Thanks
xo
RHaseltine posted Mon, 31 March 2008 at 2:50 PM
If the clothing has been made with the morphs, and if the maker gave the morphs the same name as the matching morphs on the figure (Aiko 3 in your case) then the clothes will pick up the morphs, at whatever value, and should fit fairly well. If the morphs are there but have the wrong names then you'll have to adjust them by hand on the clothes. If there are some morphs, but not the ones used in the character, then you may be able to get a fit by adjusting the morphs which are present (you'll need to select the body parts of the clothing instead of the root in some cases, as D|S disconnects the morphs on the root of the clothing when their names match the morphs on the figure wearing the clothes). If you can't get the available morphs to do the job then you can use DForms to pull the clothing into shape, or you can use an external tool such as Morph Magic to create new morphs.
missykia posted Mon, 31 March 2008 at 10:30 PM
Attached Link: Some of my Daz Studio renders
Oh okay, I knew that DForms was for somthing. Fixing the clothes by hand I can't seem to do, and then pose the figure and the clothes are stuck in the air, lol. The "Root" I see what you mean about this now. I have seen this a few times and wondered why some had them and others did not.. Thank you so much,theses are the answers to some things I have been looking for, not without trying to find them while reading first, lol Some times you just have to ask. :) I'm taking this info and tucking it away in my folder. Hugs Cathy
