Subject: Looking For Hair Dryer
javajimg opened this issue on Oct 21, 2007 · 16 posts
javajimg posted Sun, 21 October 2007 at 9:50 PM
I am looking for a hair dryer prop (not the hand held type, the type you find in a salon with the hood that goes over a woman's head).  I have checked all the usual places (including here) and cannot find one.  If someone can guide me in the right direction, it would be greatly appreciated.
Jim Gantt
Acadia posted Sun, 21 October 2007 at 11:25 PM
I haven't seen one of those around.
pakled posted Mon, 22 October 2007 at 1:09 PM
3d cafe should be a place (if they ever got freebies back; haven't been there in years. Depends on what you're looking for; the old 50s type could be modeled without too much trouble. Something later would probably require a better modeler than me..;)
Acadia posted Mon, 22 October 2007 at 1:13 PM
No, their freebie are still down. I'm beginning to think that they are never coming back. Shame too because they had some really great ones.
arcebus posted Mon, 22 October 2007 at 2:49 PM
Jim, do you need a modern one or an old style thing?
www.skin2pix.com
ockham posted Mon, 22 October 2007 at 5:23 PM
Attached Link: http://ockhamsbungalow.com/DreamVillage/HairDryer.zip
Here's a fairly simple one.  Properly sized and fitted to typical figure, and the head-part is adjustable.   You may want to add a cloth texture to the seat, and a wood tex to the armrests.......
My python page
My ShareCG freebies
javajimg posted Mon, 22 October 2007 at 6:27 PM
Quote - Here's a fairly simple one.  Properly sized and fitted to typical figure,
Thanks.  That is exactly what I am looking for.
Jim Gantt
grichter posted Mon, 22 October 2007 at 7:52 PM
That looks interesting. But my question would be to make this work with a character, where do you find a V3-V4 hair figure or prop in curlers and a hair net?
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
ockham posted Mon, 22 October 2007 at 7:57 PM
Serious or not, it's a good question.  I haven't seen any hair-in-curlers
props.   A curler itself is easy enough to make, but the complete
set of rolls would take some work!
Acadia?  Do you know of any?
My python page
My ShareCG freebies
pakled posted Mon, 22 October 2007 at 9:32 PM
closest I've seen is some roll hair for Maya Doll...wonder if it would fit...;)
DarkAngelGenesis posted Tue, 23 October 2007 at 4:29 AM
If you are still looking for a hair in curlers prop, I found one at this site here:
http://fast3d.actionbabecentral.com/index.htm
You will find it under archive 1. I think it is for Posette, but like any hair can be adjusted with some tweaking.
grichter posted Tue, 23 October 2007 at 8:43 AM
Thanks, Isaw that back a while ago. The quality of the hair texture leaves a bit to be desired. Will have to see if I can change that. Beginning modeler myself. After learning more I might have to give it a go if no one else does. Needs various hair colors and a net to cover the curlers.
Gary
Acadia posted Tue, 23 October 2007 at 10:03 AM
Quote - If you are still looking for a hair in curlers prop, I found one at this site here:
Thanks, I remember seeing that too, but didn't recall where and I don't really have time today to search.
javajimg posted Tue, 23 October 2007 at 8:25 PM
Thanks for all the replies on this topic.  I did a little experiment and hid the hair part of the curler prop mentioned above.  I then did some fiddling with the curlers to try to fit them properly around Victoria 4's head.  I only moved a couple of curlers, but it looks promising.  I can change the color of the hair around the curlers using Photoshop, so now all that is missing is the hairnet.  If no one has a hairnet, if anyone has a shower (or bathing) cap prop, I may be able to get that to work by fiddling with the texture.
Once again thanks for all the replies on this topic.
Jim Gantt
ockham posted Tue, 23 October 2007 at 8:36 PM
I'll bet you can make the hairnet by using the Cloth room.  Take the curler
prop all by itself in the scene, or maybe mount the curlers on a scaled ball
prop (to save the time needed for colliding with a complex actual head).
Lay a round flat thing on top of the curlers and let the Cloth Room drape
the round flat thing.
Find the frame where it looks best and export the OBJ; bring it
back in and give it a net-like transmap.
If you don't already have a round flat thing, here's one that
can be scaled down to do the job.
http://ockhamsbungalow.com/MiscProps/Skirt-flat.zip
My python page
My ShareCG freebies
grichter posted Tue, 23 October 2007 at 11:12 PM
Here is a shower cap. Not really a hair net and it comes with it's own hair that sticks out. I assume you could edited the hair out in the mat room and then with a net texture, make a somewhat reasonable hairnet. It loads as a Hair prop. So you can scale and trans to fit any character or V4 as you desire.
The link below is or V3. Royloo has the same item for S3P and Laura
http://poserpros.daz3d.com/store/viewitem.php?selitem=4555
Gary
