Colin_S opened this issue on Oct 26, 2007 · 15 posts
Colin_S posted Fri, 26 October 2007 at 1:07 PM
Can someone tell me what to do when an older piece of freestuff installs as P4 and PP?
I'm on P7, and the only difference I can see is the .rsr in P4 but not in PP.
Is it something to do with the MATs? Which one can I delete?
SamTherapy posted Fri, 26 October 2007 at 1:22 PM
Go for the ProPack version. The difference is in the bump maps. Poser 4 uses red/green BUM files, all other versions onward generally use greyscale JPG for bumps.
That said, Poser 6 (and I guess 7) can use BUM files but they are generally not used now because they're larger files than the greyscale versions. Word of warning, though - greyscale maps should be plugged into the Bump channel, not the Gradient_Bump channel. Chances are the default MAT poses will connect them wrong.
geep posted Fri, 26 October 2007 at 1:26 PM
Hi Colin_S,
Poser 4 used the .rsr file for the thumbnail image in the Library.
Pro Pack started using .png files for thumbnail images.
You don't really need either one because ...
If the thumbnail image i.e., .rsr or .png, is missing, you will see the little shrugging guy in the Library.
How to make a new thumbnail image.
Poser will create a new thumbnail image for the Library.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
MatrixWorkz posted Fri, 26 October 2007 at 1:31 PM
Poser 6 & 7 will automatically create PNG files for your library using the old RSR files, not sure about Poser 5.
Lucifer_The_Dark posted Fri, 26 October 2007 at 1:57 PM
Poser 5 does it too, that's if you can actually get it to run for more than 5 seconds (I'm kidding)
Windows 7 64Bit
Poser Pro 2010 SR1
BecSchm posted Fri, 26 October 2007 at 5:31 PM
Get rid of P4. P4 will give you very annoying messages if it needs a BUM fle and can't find it. PP generally loads all the maps in my P6 much easier.
asrailight posted Fri, 26 October 2007 at 6:24 PM
What about when you have files that give you an option of P4, PP, P5 or P6? Which should you choose? I noticed that the PP version of one of my props rendered blown-out, but the P5 version was fine. On other props, the PP version looked better, if there was any difference at all.
pakled posted Fri, 26 October 2007 at 10:09 PM
I can get P5 to run for way more than 5 seconds...just ask it to find a texture that's not in the right place...;)
MatrixWorkz posted Fri, 26 October 2007 at 10:28 PM
Quote - I can get P5 to run for way more than 5 seconds...just ask it to find a texture that's not in the right place...;)
plus3d posted Sat, 27 October 2007 at 2:07 AM
PP is excellent !!!
I still use it a lot for Poser creations. It´s fast and renders are fast and clean (attention: the shader tree settings aren´t rendered, just the simple settings are loaded to be rendered).
PP is excellent!
Plus3D
My freebies at Renderosity -
CLICK HERE :)
Colin_S posted Mon, 29 October 2007 at 1:01 PM
Thank you everybody
Lucifer_The_Dark posted Mon, 29 October 2007 at 2:08 PM
OUCH!!! I was trying to forget that ever happened! hehehehe
Windows 7 64Bit
Poser Pro 2010 SR1
Dajadues posted Mon, 05 November 2007 at 2:32 AM
I use P5 no problems for a long time now.
And, I've never had that happen with textures.
I will never part with it. I loves me ProPack.
And, oddly enough, it's rendering faster than Daz Studio.
Oh and delete P4 and keep PP. You don't need P4
unless there's no PP, then, you'll need to keep it.
Lucifer_The_Dark posted Mon, 05 November 2007 at 5:52 AM
With Poser5 it used to drive me crazy when it went into a sulk cause it couldn't find textures but thanks to Hogwarden & his brilliant Correct Reference program the problem went away fast.
Windows 7 64Bit
Poser Pro 2010 SR1
Dajadues posted Mon, 05 November 2007 at 11:15 PM
**Lucifer_The_Dark
**I can safely say with using P5 I have never had that prob.
If I did it was because the textures were either missing or not
the right path in the file it's self which, is usually the problem.
If the path is wrong, Poser will not find it. I fix that by editing
the file and changing the path in notepad. Thats just me
tho. I don't mind taking the time to edit a .cr2 or a prop file.
