choover3 opened this issue on Oct 27, 2007 · 7 posts
choover3 posted Sat, 27 October 2007 at 6:48 AM
This is probably lame. In D|S you can select "MAT" in the surfaces tab to eliminate the plastic look. Is there something that simple in the Poser materials?
My panther would look better if it wasn't so shiney!
bagginsbill posted Sat, 27 October 2007 at 8:00 AM
Set the Specular_Value = 0 in the material room. Then there is no shine.
I haven't seen what you're rendering, but you mentioned a panther. Fur and skin is neither shiny nor mat, but somewhere in between. I agree you don't want a "plastic" shader, but dropping the specular altogether is not the best answer.
Try Specular_Value = .05 to .3, and Roughness = .05 to .2. Experiment with these on a simple object like a sphere. Get to know how these looks, and then you'll be able to dial these in from memory.
choover3 posted Sat, 27 October 2007 at 8:06 AM
Thanks!
I'll give it a try.
I really want to get a handle on the Material Room.
pjz99 posted Sat, 27 October 2007 at 8:31 AM
There are two views for the Materials Room, Basic and Advanced. While the Advanced view is intimidating at first, too much is hidden from you in Basic view, so if you really want to learn it, switch to Advanced view - everything in there is documented fairly well in the manual.
choover3 posted Sat, 27 October 2007 at 8:35 AM
Much better!
Thanks again.
asrailight posted Fri, 07 December 2007 at 11:18 AM
Any idea what "roughness" translates to in Poser 7? I can't find it in the material room, nor in the manual... :(
bagginsbill posted Fri, 07 December 2007 at 11:45 AM
The PoserSurface has a built-in "Diffuse" node and a built-in "Specular" node, along with a bunch of other stuff. The parameters for a Specular node are:
Specular_Color
Specular_Value
Roughness
Normals_Forward
For some stupid reason, the Specular built in to PoserSurface calls it Highlight_Size.
They mean the same.
