hamiltonpl opened this issue on Nov 04, 2007 · 7 posts
hamiltonpl posted Sun, 04 November 2007 at 2:08 PM
I have a 260 frame animation in Poser. It is saved as PZ3 file. I was able to bring this into VUE Easel with no problem and then render it. When I did the anmation with Poser played across the frames.
I upgraded to Esprit so I can animate objects other than the camera. I bring in the SAME PZ3 file I did before and I make sure that I check the box that say bring in all frames but now the animation will not play. It just renders frame 1.
I must be doing something differently. I cannot figure out why the animation doesn't play inside Vue. It did before. Am I leaving out a step? tks.
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
