Black_Star opened this issue on Nov 11, 2007 · 7 posts
Black_Star posted Sun, 11 November 2007 at 8:43 AM
Hi!
I have an image that is higher than wider, meaning you can simplify it down to a line.Now, how can I wrap this line to the margins of a perfect circle without distorting it (apart from wrapping)?
Is there any way to choose the amount of degrees the images will follow?Something that will also let you wrap it around a circle, but only for 180 degrees and not the full 360 degrees.Also, fitting the length of the image with that of the circle would be nice, so that the image will not become "longer" in the process.
And in the same order of ideeas, such an image can be transformed into a helix?
All these three things I am askig for, I have seen them done before, but I don't know how.
Thank you in advance!
Best regards!
Thelby posted Sun, 11 November 2007 at 8:56 AM
The age old problem is not being able to see the image in Question and Diagnose a Correct Response, but being at work as I am now, what about the "TWIRL" function? For 180 degrees is should be OK although it will not work for the full 360. As far as the image being longer than wide, you can always change the size of the Canvas so that both Match. But, Again, I am not looking at your image and may actually be off base about what I interpret you are wanting to do.
Sorry I can not be more Currently!!!
P.S. Also, what Version of Photoshop are you using???
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
spedler posted Mon, 12 November 2007 at 3:44 AM
For wrapping an image into an arc, and assuming you are using CS2 or higher, do this:
Steve
Black_Star posted Mon, 12 November 2007 at 11:28 AM
I am using Adobe Photoshop CS.
Thelby posted Mon, 12 November 2007 at 11:35 AM
So that is why I could not do it. I have a Personally Modified Version of PS7 in combo with CS. It doesn't have the function,................................ Hmmm, Time to Upgrade !!!
I would rather
bonestructure posted Fri, 16 November 2007 at 2:33 PM
Create a path, distort the line along the path. I think. Never done it, but I think that's how ya do it.
inshaala posted Tue, 20 November 2007 at 8:28 AM
Tried polar co-ordinates under distort on your filter menu? It picks the top as the centre normally and compresses that whole upper edge into a dot and wraps the rest of the photo around it. Interesting effects can be made with it. Not really sure what you are asking to be honest...
"In every colour, there's the light.
In every stone sleeps a crystal.
Remember the Shaman, when he used to say:
Man is the dream of the Dolphin"
Rich Meadows Photography
