Subject: Poser figure creation program???
alphauser51 opened this issue on Nov 12, 2007 · 4 posts
alphauser51 posted Mon, 12 November 2007 at 2:00 PM
Can anyone suggest an alternative application to Poser for creating
rigged figures for poser? The creation tools in Pose are awful, and extremely
difficult to get clean results.
Also, I need someone to create 2 simple posable figures
from meshes I have for a project Im working on.. No morphs, just need the figures joints to move realistically. Need soon , will pay.
kuroyume0161 posted Mon, 12 November 2007 at 3:04 PM
Other than Greenbriar Studios Toolbox II Poser ($99), there really isn't one.  I suggest getting acquainted with the Phi file and PhiBuilder for initial rigging in Poser.  Then use the Joint Editor to tweak - avoid the Setup Room for rigging!
PhilC may have some nice Poser Python script tools to assist in the process so check out his website.
 -- Bjarne Stroustrup
Miss Nancy posted Mon, 12 November 2007 at 3:19 PM
alph, post images of the two figures. the quick way is to add two lines referring to the new figure object file to a similar pre-existing EF cr2 file (if for redistribution) or to a similar pre-existing daz cr2 file (no redistribution).
kuroyume0161 posted Mon, 12 November 2007 at 4:02 PM
If there is a comparable figure with at least the same body parts (obj groups).  Either way (Phi or CR2 reuse) one will still need to tweak with the Joint Editor.
