Torulf opened this issue on Nov 12, 2007 · 2 posts
Torulf posted Mon, 12 November 2007 at 5:37 PM
I do not understand the animation layerss. Its looks a little bit complicated due to the manual. Are there any tutorial?
I want to make a work threw walk designer.
And get only the abdomen and lower to be affected, for the chest and upper I want to keep the original pose.
If I understand it right this can be made threw animation layers. Or is there any different method for do this?
TG
kuroyume0161 posted Mon, 12 November 2007 at 6:09 PM
One way here would be to apply the walk with Walk Designer and then delete the animation on the body parts where you don't want it to remain.
But, you could also create a new Animation Layer and animate these other body parts as you like. Set the mode to Replace for Animation Layers. This means that the animation of those body parts on the Base Layer (or lower layers) will be replaced by that of the new layer. This should work for still pose as well - as long as you set the Start/End for the layer to cover the animation.
off.
-- Bjarne
Stroustrup
