Forum: DAZ|Studio
Subject: How do I get good object ground shadows in DS?
UVDan opened this issue on Nov 15, 2007 · 26 posts
UVDan posted Thu, 15 November 2007 at 10:07 PM Forum Moderator
**Seriously, how do I get good ground shadows? **
Free men do not ask permission to bear arms!!
AnnieD posted Thu, 15 November 2007 at 10:40 PM
I'd like to know the same thing..  :D
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
Heztia posted Fri, 16 November 2007 at 1:06 AM
I'm still learning shadows but what I've come to find is having the lights in my scene parented to a null on the floor.  Also for me the light that creates the shadow is a spotlight and is set at a higher value then the other lights.  I don't know if I explained this right or if it anwsers your question as I said I'm still working on shadows myself :0)
"KnowThyself And Be Ture, Let Karma Do The Rest"
Mystic Images Freebies
JenX posted Fri, 16 November 2007 at 3:08 AM
In general, when lighting a scene, I find Distant Lights more efficient and work better than spotlights.  Another tip.....Play with your shadow softness and bias.  In nature, rarely is your shadow hard on the edge.  Never is your shadow the same from one light to another...for instance, right now, there's a light on in my living room, uncovered lightbulb, and there's a light on in the stairwell, covered lightbulb.  The shadows in my living room are harsh and ugly.  The shadows in the stairwell are soft and subdued.
Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it into a fruit salad.
UVDan posted Fri, 16 November 2007 at 4:05 AM Forum Moderator
Thanks everyone.  I am using distant lights, but find I either have my floor totally shadowed or none at all.  I guess I will work with it some more.
JenX posted Fri, 16 November 2007 at 4:11 AM
Are you changing the angle of the lights, Dan?  The easiest ways to do that is to use the light as a "camera", and rotate it and move it to where you want.  Well, that's what I do.  ;)
UVDan posted Fri, 16 November 2007 at 5:44 AM Forum Moderator
**Thanks everybody.
  Yes I definitely am changing the angle of the lights.  I am trying out DS because of the  Puppetmaster feature.   I have never seen such a fun way to animate.  I wish Carrara 6 could open up a DS file and preserve the animation though.
What is this using a light like a camera?  Can I look through the light?  I can watch the scene while I rotate the light around to see where it goes.  Is that what you mean?  I wish the lights were selectable from the scene tree  when I am in lighting and render mode.**
JenX posted Fri, 16 November 2007 at 5:56 AM
I have to run, but when I get home this afternoon, I'll post some screenshots of what I mean, ok, Dan ;)  Sitemail me if I forget, LOL.
dvlenk6 posted Fri, 16 November 2007 at 8:22 AM
Quote - What is this using a light like a camera?  Can I look through the light?  I can watch the scene while I rotate the light around to see where it goes.  Is that what you mean?  I wish the lights were selectable from the scene tree  when I am in lighting and render mode.
Yeah, you can switch your viewport to see the scene from the view of a light. As you move around the viewport, the light moves w/ the view, just as if it were a camera. It's really nice when you have a spot w/ 'point at' turned on. Makes it easy to place spotlights.
Friends don't let friends use booleans.
Heztia posted Fri, 16 November 2007 at 12:04 PM
I guess if your wanting your shadow to on the "whole" ground surface  having a distance light as your shadow caster is good.  If it just your characters then the spotlight is better, at least for me.  Using the light as a camra is an excellent way to postion the light to where you need.  You need to be patcient though as I've found sometime finding just the right spot is not always easy and it takes time.
Hope you get it, have fun! ;0) Heztia
jestmart posted Fri, 16 November 2007 at 9:58 PM
The problem with distant lights is they have no point of origin.  They are infinite light that illuminate the scene completely at a specific angle.  If your scene is the interior of a building the walls, floor and ceiling will cast shadow unless you turn cast shadow off for them.
prixat posted Sat, 17 November 2007 at 3:14 AM
What you might be missing is the Ambient setting on your floor material. Ambient is the colour of something when there is no direct light shining on it. i.e. the colour of the shadow. So you can get stronger shadows by setting ambient to black.
regards
prixat
JenX posted Sat, 17 November 2007 at 3:12 PM
Ok, here's how I start out, Dan.  I set up my scene, no lights.  I prefer Distance Lights, so that's what I use.
JenX posted Sat, 17 November 2007 at 3:15 PM
I add my first light, and I want to set it up where I want it, without using the dials, because they're not as accurate....so, I go to the display drop-down menu to select the light to use it as a camera (Note: You can't render with a light as your camera).
I select my distance light from the drop down menu...
JenX posted Sat, 17 November 2007 at 3:21 PM
The distance light will encase your whole scene, and the spotlight will start at the exact zero on the X, Y, and Z axes in DS.
JenX posted Sat, 17 November 2007 at 3:22 PM
I rotate it to where I want it to be...
And, I go back to my main view.  It's a little dark, I need another light.
JenX posted Sat, 17 November 2007 at 3:23 PM
Ok, added the new light.....
JenX posted Sat, 17 November 2007 at 3:24 PM
Now, to select it from the drop-down again, so I can move it to the angle I want it at.
JenX posted Sat, 17 November 2007 at 3:25 PM
I want this one in front, so I want to rotate it to where I want it.
Now, Back to the main camera.
JenX posted Sat, 17 November 2007 at 3:26 PM
Now, select the light you want to have shadow (you can do this for all of your lights, but I prefer to do it for just one) in the Scene palette.
JenX posted Sat, 17 November 2007 at 3:28 PM
Now, select the kind of shadow you want (Mapped or Raytraced...I prefer Raytraced, myself), and the softness of the shadow, as well as the bias.  I chose a softness of 50% and a bias of 2.50.
JenX posted Sat, 17 November 2007 at 3:30 PM
And, after 3 1/2 hours of rendering (hey, I"m cleaning my house, so patience has nothing to do with it!), here's the finished image. I prefer the softer shadow.  It mimics, but doesn't exactly replicate, AO, and that's good enough for what I'm doing in D|S.
UVDan posted Sat, 17 November 2007 at 9:24 PM Forum Moderator
Thanks to everyone and especially to JenX for the fine tut.  I hope this works on ground shadows like it does on figure shadows.  Your ground is so dark, I cannot tell  how the shadows  are there.
