offrench opened this issue on Nov 17, 2007 · 3 posts
offrench posted Sat, 17 November 2007 at 2:39 PM
I am having problems exporting plants from Vue 6 Infinite.
When I export plants and select "generate color maps" Vue crashes upon export.
When I do not select this, and only export to .3ds or obj format, the export goes well, but the resulting mesh is a useless jumble of polygons. I select the resolution to get exactly the same number of polygons as on my object (in that case : 4480) and the exported object only has 1320 polygons.
I tried to export an object I had made myself and used in Vue and it did so normally.
Is there a way to export plants or is this function broken?
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
lingrif posted Sat, 17 November 2007 at 3:11 PM
This was fixed in a recent release. be sure to apply the latest update and it should work fine.
offrench posted Mon, 19 November 2007 at 1:59 PM
Well I have done the update. Still does not work for me.
Export without maps still gives me a geometry that is totally unusable.
Export with maps gives a correct geometry, but the "generate alpha map" button is disabled and I cannot export the transparency.
BTW: how can I have access to the maps used for the leaves and branches ? I would like to make my own ones and need a template.
Fantasy pictures,
and
