Subject: Question re: .vob file extension
Acadia opened this issue on Nov 19, 2007 · 13 posts
Acadia posted Mon, 19 November 2007 at 8:29 PM
I know the .vob extension is for Vue. I have the free Vue 6 Infinite PLE
I found a freebie that I would like to use and it has a .vob extension and I want to convert it to .obj so I can use it in Poser.
The readme for the file says:
[quote]To Install:
Where in the Vue folder do I find the folder that has the objects in it?
in the top level of the Vue folder I have the following:  Application, Documentation, Environment, Help, Modules, and Python.  I've looked in each of those and don't see any "object" folders.
diolma posted Mon, 19 November 2007 at 8:50 PM
Hi Acadia.
Drop the .VOB anywhere - any folder anywhere.
Start V6I PLE. Go to File Menu->Load Object. You should get the "Top level" dialogue. At the bottom of that dialogue there's a browse option (next to the waste bin - hover over the icons there). Click the browse option and you should be able to browse to wherever you saved the .vob and load it.
However, I rather think that you won't be able to save it out as eg. a .obj file (tho I hope I'm wrong).  Many .VOB files are set up so that they cannot be re-exported.
However, just in case I'm wrong, to try to do so select the object, and go to File Menu->Export Object. Select .obj format.
Hope that works (I have V5I, not V6I, but I'd be surprised if these bits have been changed)
Cheers,
Diolma
Acadia posted Mon, 19 November 2007 at 8:59 PM
Thanks :)  I'll give that  a try tomorrow. Right now my bed and book are calling out to me.
jenay posted Tue, 20 November 2007 at 10:30 AM
let me know if you are successful .)
as far as I read the doku it's not possible to interchange files with the PLE of Vue. maybe I am wrong ...
SSAfam1 posted Tue, 20 November 2007 at 11:31 AM
Acadia what do you use Vue for? What are the pros?
svdl posted Tue, 20 November 2007 at 12:12 PM
Vue is a landscape generator and renderer.
Pros of Vue:
Cons of Vue:
My gallery   My freestuff
Acadia posted Tue, 20 November 2007 at 12:27 PM
Quote - Hi Acadia.
Cheers,
Diolma
I can't seem to load the .vob object file. I get some message saying that Vue 6 can't read files for Vue d'esprite or earlier and to use the conversion tool to convert the file.
Acadia posted Tue, 20 November 2007 at 12:29 PM
Quote - Acadia what do you use Vue for? What are the pros?
I have no idea!  LOL I saw someone talking about the free version of Vue so I decided to download it and try it out. Apparently renders are supposed to be much better or something. TBH I even though I installed it,  haven't bothered with it. I'm still trying to figure out Poser and with me it's one program at a time because I'm easily overwhelmed when I try to learn too many things at the same time.
SSAfam1 posted Tue, 20 November 2007 at 12:34 PM
Yeah I know StormChaser loves Vue for rendering but didn't know if the free version would come equipped with all the things needed.
FrankT posted Tue, 20 November 2007 at 1:20 PM
Few more pros for Vue
Volumetrics - you can see 'em in the preview and they render much faster than Poser.
GI and GR without having to hack secret settings (and which work )
Placement of things that aren't in Ecosystems is actually as precise as Poser - you can adjust Z Y and Z independently if you need to.
Density maps for Ecosystem layout and ecosystem painting in Infinite, surprisingly useful
and yeah - almost all my renders are done in Vue these days - 900x1500 in 2 or 3 mins with volumetrics (but not with GI obviously)
My Freebies
Buy stuff on RedBubble
SSAfam1 posted Tue, 20 November 2007 at 1:34 PM
^Are these available in the FREE version as well?
FrankT posted Tue, 20 November 2007 at 1:37 PM
you'd have to check the website but so far as I know ecosystem painting is available in the PLE.  The rest of it certainly should be
My Freebies
nruddock posted Tue, 20 November 2007 at 1:55 PM
Quote - I can't seem to load the .vob object file.
As someone else mentioned, the PLE has a restriction that stops it from loading files from non-PLE versions.
